586,055 active members*
4,068 visitors online*
    Help Me Troubleshoot
    Making these signs have about 30/200 done and the laser is beginning to about 75% of the time get off track in around the same area everytime. Don't understand what is happening as 90% of the time the first line is always fine. I have checked for obvious obstructions is all at this point. Please see the picture to help me learn where to start adjusting. Thank you it is an important project for my work and I want to be able to finish the rest of the signs.
    I have this engraver: https://engraverworld.com/collection...raving-machine
    This is my problem. You can see in the ijmage it is off on the letter g's and, lowercase s, and Pi.
    Nov 2008
    643
    Re: Help Me Troubleshoot
    It appears that the X axis is loosing steps. Is something causing resistance or additional weight on that axis? Hose dragging?
    You can also check for and tighten pulleys on shafts. Make sure the belt isn’t riding on the pulley flange.
    Check that the stepper motor isn’t getting very hot. Increase the amp setting on the stepper drive as a last resort. But that might increase the temperature
    Apr 2005
    304
    Corrupted USB communication.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
  1. Replies: 7
    Last Post: 01-22-2021, 09:11 PM
  2. How to troubleshoot the vacuum pump?
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 01-30-2016, 10:29 AM
  3. 48V Relay troubleshoot
    By zephyranthes1 in forum CNC Machine Related Electronics
    Last Post: 04-02-2011, 09:12 PM
  4. Help troubleshoot Lincoln SA 200
    By aawelderswife in forum Welding Brazing Soldering Sealing
    Last Post: 07-19-2008, 03:08 AM
  5. Troubleshoot DNC
    By phoodieman in forum Uncategorised MetalWorking Machines
    Last Post: 09-21-2006, 07:44 PM
