603,390 active members*
2,783 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Help with Mill/Turn Problem.
Results 1 to 10 of 10
    Jul 2013
    32
    Hi to you all, just getting acquainted with FC 2013 and finding it a very nice package. So far I have created a few simple standard milled components using the milling features and have also created a few simple parts for the lathe using the Turn functions.
    Today I tried to create a part for the turn/mill but when I tried to simulate the machining I encountered the following error:
    TCG08 Operation has been assigned to a turret that does not support live tooling.
    I have checked the various properties boxes and I can only see one turret available to me which is the Upper Turret. Is there something I need to alter in the settings to enable the upper turret to support live tooling?
    Thank You.
    Jul 2010
    369
    j206
    You need to select a Post Processor that supports live tooling.
    "See attached"
    The highlighted area is where you can click and choose/change the post that you are using.
    Hope this helps.
    Good Luck~!:cheers:
    Jul 2013
    32
    Hi PC, thanks for the help, you was certainly on the right track there but it looks like I do not have any turn/mill post processors. Found the posts folder and the turn mill folder is empty! Don't know what has happened there.
    Any idea how I can find a post processor, just looking for a standard FANUC one, I can always make any tweaks to the nc code before I send the code to the machine.
    Jul 2010
    369
    Re: Help with Mill/Turn Problem.
    Give this one a try j206 :cheers:
    Attached Files Attached Files
    Jul 2013
    32
    Well, thanks for the post PC, I think we are going to have to upgrade our old shop floor laptop. Its been refusing to install any updates of late so unfortunately the post processor you gave us wont open in our version of FC (8.135). We might have to wait a few weeks/months for the boss to upgrade us to a better newer laptop.
    Thanks anyway, really good of you to help.
    Jul 2010
    369
    Wow!
    Version 8.135 ?
    That is a very old version.
    FC is up to 20.6 now.
    Maybe an upgrade with that new laptop?
    Best of luck :cheers:
    Jul 2013
    32
    By the sounds of things, they have not bothered updating it since they purchased the system. In fact as far as I can gather, they haven't really used it at all, its just been on the laptop which is now at the end of its life so once we get the new laptop, I will try get everything up to date.
    Thanks again
    Jan 2015
    11
    Many thanks for the PP, now i can tweak a little bit and make this work for my lathe!!
    Nov 2015
    Quote Originally Posted by Perfect Circle View Post
    I know it's been a while. Any chance of re-posting your TURNMILL.zip file. Not able to download it. Not sure if I'm doing something wrong or maybe it's not available for download any longer on the server.
    Thanks!
    HI Guys
    I need any mill turn post for fanuc. I tried this one but I have featurecam 2012 and its not opening this port. Can anyone help???
  1. Problem with Bobcam for SW Turn.
    By oldraven in forum BobCAM for SolidWorks™
    Last Post: 05-18-2014, 12:52 PM
  2. MachStdMill Turn and Mill-Turn Announcement
    By mvcalypso in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-16-2012, 03:38 PM
  3. Announcement: MachStdMill Turn and Mill-Turn
    By mvcalypso in forum News Announcements
    Last Post: 04-12-2012, 07:59 PM
  4. mill/turn on a cin turn
    By Robert Timby in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2007, 05:33 AM
  5. Cin Turn turn/mill
    By Robert Timby in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-25-2007, 02:12 AM
