I'm working on connecting my first cnc machine. Right now I have a Keling c10 BOB with a KL4030 driver and 36V power supply.
I've connected the first stepper (270oz/in) and tried to test it and ran into troubles already.Using EMC2, when the X-axis tries to move the motor bumps, makes a bit of noise and shifts on the table, but the axis never spins. If I decrease the voltage from the driver I can hear that it doesn't bump as hard, but still no spinning.
I've already checked the 5V power to the board and linked it to the en.
I switched the jumper so that the common port is 5v.
4 wires go from the BOB to the driver (ENA+ and - are empty per the diagrams)
B- has the blue wire, B+ has the red wire, A- has the green wire, A+ has the black wire, GND- goes to V-, VCC+ goes to V+
Any help or thoughts would be appreciated
Thanks,
Nate
