603,314 active members*
1,862 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Techno CNC > Help mounting motor on Techno DaVinci
Results 1 to 4 of 4
    Mar 2017
    I am trying to help a high school teacher get his DaVinci up and running. Apparently it is a few years old, but has never been run. He needed to move it from one room to another after he first got it, but it was too large to fit through the door. He took one of the motors off to get it to fit, but in doing so broke part of it. He has since sent that part back and had it repaired, but now doesn't know how to remount the motor. He said he reached out to Techno, who said they no longer support this machine. He did get someone to give him a quote to come repair it, but the quote was $2500 for an afternoon. Looking at the pictures he sent me, it doesn't look very complicated, but I've never worked with this machine before so I don't know how to guide him through it. Maybe someone else with this same machine can just take a picture of what theirs looks like? Any help would be appreciated!
    Attached Thumbnails Attached Thumbnails IMG_0909.JPG   IMG_0910.JPG   IMG_0948.JPG   IMG_0947.JPG
    Aug 2006
    132
    Re: Help mounting motor on Techno DaVinci
    The motor mounts to a stand-off/adapter (square block item) and the stand-off/adaptor mounts to the plate on the side of the machine.
    The motor has a coupler on the shaft that also interlocks to it complementary part on the machine side.
    I cannot see the details of how the machine-side coupler part drives the axis shaft/screw.
    The stand-off looks like the NEMA type on THIS page.
    I found THIS link on their site. Download the manual and several pages into it you will find a diagram showing the mounting of the motor and associated parts.
    Good Luck! That looks like a great machine for a school program.
    -=Doug
    "IT ≠ IQ " Starwalt 1999
    Mar 2017
    Thank you very much Doug! This is very helpful. I will pass this along to the teacher!!
    Sep 2012
    230
    Alex,
    check out the Z axis on that machine - the Y axis mount is identical to it.
    One thing to watch for - if the machine complains it's at the end of travel when you start up and/or it won't home properly, flip the small black connector that plugs into the coupling box's circuit board around 180 degrees. Nothing bad happens if it's backwards - it just won't see the home switch.
    Eric
    Eric Feldman - Design Engineer, Programmer
    Armor CNC - http://www.armorcnc.com Support hours: 7am thru 10pm EST, 7 days a week
  1. johnohara's Techno-Isel DaVinci
    By johnohara in forum Techno CNC
    Last Post: 01-26-2021, 01:37 PM
  2. Techno-Isel Davinci upgrade help
    By Ferny in forum Controller & Computer Solutions
    Last Post: 08-05-2020, 12:25 PM
  3. Techno Davinci upgrade - looking for advice
    By dixdance in forum Techno CNC
    Last Post: 02-21-2017, 05:15 PM
  4. techno davinci book or pdf
    By grebber in forum Techno CNC
    Last Post: 04-27-2015, 01:01 AM
