603,965 active members*
2,529 visitors online*
Thread: Help needed
    Nov 2005
    Help needed
    Hello everybody...
    I'm taking a manufacturing course where we are introduced to CNC Milling.
    I have a lab report due today, and while I was searching online, I found cnczone.com. I hope you can give me some help.
    I've got the following code, and I have to explain the functions for each block. Would you be kind enough to take a look at it and correct me if i'm wrong. Also fill in a couple of blank ones?
    Thanx!
    Code:
    (DATE=DD-MM-YY - 07-11-2005 TIME=HH:MM 09:15)
    N100 G20 # Inch mode
    N102 G0 G17 G40 G49 G80 G90 # Select the X-Y plane, turn off the path compensations, canned cycle and start absolute programming
    (1/4 FLAT ENDMILL TOOL-2 DIA. OFF. – 2 LEN. – 2 DIA. – .25)
    N110 T2 M6 # Change to tool 2
    N112 G0 G90 X0. Y0. S3200 M3 # Spindle clockwise at a speed at 3200 RPM
    N114 G43 H2 Z.25 # Initialize tool length compensation at a 2 inch
    height and bring the tip of the tool to the position
    Z.5
    N116 Z.1 # spindle stop and return to
    N118 G1 Z-.1 F4. # Drill at the position Z=-0.1 inches with a feed rate
    of 4 in/min
    N120 Y2. F8. # Apply a feed rate of 8 in/min in the Y 2in position
    N122 X1. #
    N124 G2 X2. Y1. R1. # Circular clockwise interpolation with a radius of 0.5 inch and end at position X=2 inch and Y=1 inch
    N126 G1 Y.5 # Drill at the end position (Y=0.5 inch)
    N128 G2 X1.5 Y0. R.5 # Circular clockwise interpolation with a radius of 0.5 inch and end at position X=1.5 inch and Y=0
    N130 G1 X0. # Drill at position X=0
    N132 G0 Z.25 # Rapid transverse at the point Z=0.25 inches
    N134 M5 # Spindle off
    M136 G91 G28 Z0 # Incremental programming
    N138 G28 X0. Y0. # Tool returns to the home position (0,0)
    N140 M30 # End of program
    Mar 2004
    761
    Quote Originally Posted by BlackIbanez
    Hello everybody...
    Thanx!
    Code:
    N114 G43 H2 Z.25 # Initialize tool length compensation at a 2 inch height and bring the tip of the tool to the position
    Z.5
    of 4 in/min
    N122 X1. #
    H2 Calls tool length offset H2.
    Note : Cincinnati Mills use H1 ...Hx as fixture offsets.
    The G1 lines are moving at the last F rate. - Not drilling.
    M136 G91 G28 Z0 (Returns Z axis to home position)
