603,344 active members*
3,678 visitors online*
IndustryArena Forum > MetalWorking Machines > Bending- and Punching Machines > Help needed to change language in Cybelec CNC DNC 1200 PS/A
Results 1 to 4 of 4
    Sep 2014
    3
    We don't know why we cannot change the language in the cybelec cnc controller
    It gives an error message as it needs the switch to be in position 3, the switch is in position 3 but with no effect
    Is there any other condition that needs to be fulfilled in order to change system.parameters?
    Apr 2020
    Re: Help needed to change language in Cybelec CNC DNC 1200 PS/A
    If you are in USER LEVEL 3 then the only other thing that should be required is that you are in PROGRAM mode.
    Oct 2010
    I recognize that this thread is extremely old and that this person likely no longer needs and answer. But maybe this information can be helpful to somone else along the way in the future.
    If you attempt to change the language in Cybelec DNC software and find that it immediately reverts back to its previous selection this almost always means that the version of Cybelec being used requires a dongle key to function and the system is not finding the security dongle. On old systems this dongle was in the form of a key that plugged into the "Printer" port on the CPU card. On newer versions this dongle key was in the form of a USB plugin that is plugged into one of the USB ports on the CPU card. In the case of this failure you either do not have a dongle security key, or the key or the port it is plugged into is not working poroperly for the dongle to be identified. You must resolve this dongle issue prior to being able to use the software.
    Hi good morning we have a Cybelec CnC controller attached to our Colly Press brake, but I have an issue with the controller which is a Cybelec Modeva12s DNC 1200
    Which is not working with Cybelec Software only responds to windows software in the background the screen doesn’t respond neither do any buttons,
    im trying to understand what the issue could be , and any help and feedback would be appreciated
    Thanks & Regards
    Steve
  1. DRO Language change
    By Navpreet in forum Complaints and Praise Discussions
    Last Post: 02-01-2020, 04:37 PM
  2. Change The language
    By Mouad in forum Fanuc
    Last Post: 01-22-2020, 10:34 AM
  3. Help needed: How to change language
    By lilee in forum Turning
    Last Post: 11-03-2018, 05:19 PM
  4. Change language of 21i-m
    By fomaz in forum Fanuc
    Last Post: 10-03-2009, 07:14 AM
  5. Language change
    By 5assi in forum Mastercam
    Last Post: 07-16-2008, 05:14 PM
