603,960 active members*
3,789 visitors online*
IndustryArena Forum > MetalWorking Machines > Dyna Mechtronics > Help needed, RS232 to USB to run the DM3000
Results 1 to 6 of 6
    Oct 2006
    30
    I want to run my lathe from my laptop, but the years between the electronics make it some what dificult? Can I make or buy a cable to link my PC/lap top to the RS232 port on my DM3000 Lathe?
    Thanks, Rick
    Aug 2010
    156
    try this
    Digi Connect SP - Compact Serial Server for Custom Applications - Digi International
    we use them on 32 machines here with very good results.
    it will let you use your network conection on your computer and then switch to rs232 to the machine.
    we run network cable from office to machine and use this device with a 3 foot rs232 cable
    Oct 2006
    30
    Thanks for the link. Have you used them on the DM3000?
    Plug and play sounds good, but they are a lot of money for something that may not be compatable?
    Jan 2006
    2985
    If your DM3000 takes RS232, then this WILL work: Mini USB to Serial Converter | Mini USB to RS232 - B&B Electronics
    The drivers make it appear just like it was a COM port on your computer. I use them for lots of different equipment with labview, matlab, hyperterminal, realterm, putty, etc.
    Just do yourself a favor and don't buy the ebay RS232 to USB converters. Lots of problems with drivers and other headaches.
    Matt
    Jul 2004
    175
    Rick,
    If you are looking to upload and download programs to the machine, we sell cables on the website. We also have a USB to serial device that works 100% with a variety of CNC controllers. We have documentation on this machine as well. Optionally, if you want to get fancy, you can use a Digi SP or something like that ethernet to serial device but overkill for your application for 1 CNC.
    We have used the Digi in the past but had problems with reliability and warranty service, so we stopped recommending this model.
    Greg Mercurio -Shop Floor Automations
    www.shopfloorautomations.com /619-461-4000
    Nov 2008
    17
    What is the web site?
  1. I need a DM3000 maintenance manual
    By macatoms in forum Dyna Mechtronics
    Last Post: 02-21-2012, 01:22 AM
  2. dm2400 / dm3000
    By willyh in forum Benchtop Machines
    Last Post: 09-18-2010, 09:44 PM
  3. Dyna mechtronics DM3000
    By Raskins in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2008, 12:26 AM
  4. V2XT RS232 pinouts needed
    By zcases in forum Bridgeport / Hardinge Mills
    Last Post: 04-16-2005, 01:15 AM
