Have problem with filling tank on a Sodick A500w Mark-21c from 1996-10
Water circulation is working fine, but when I trying to filling the tank the pump just stops and every 18 seconds the relay tries to
start the pump for about 0,5seconds with bad noice from relay and the relay dont pull.
If I stop filling the tank the pump starts perfect again.
This happends after a very long stop and we have change the battery on both cpu cards and changed all water in the machine.
We also loaded the software from flopp disc.
( A half year ago the machine lost the memory and loaded the software and got the machine up and running perfect, but we discovered that the
level sensors in the tank was had reversed funktion.
Then we change funktion and it was running perfect.
This is not the problem this time )
Any one who know something about this problem or have electrical drawings??
Please help.
// Daniel
