603,546 active members*
1,373 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Help needed using Cimatron 2024's Turing module
Results 1 to 5 of 5
    Apr 2021
    7
    Question Help needed using Cimatron 2024's Turing module
    Hello all,
    I seem to have an issue with Cimatron when trying to make a turning procedure, at NC Setup it requires me to select a machine, which presumably is a folder, something similar like in the image attachment below.
    Now since the lathe is a converted one with a kit (Chinese), I don't believe they provided such a file. I would appreciate it if someone could share a similar one with me, I can modify it to suit the said lathe which will allow me to make CAM procedures for it.
    Thank you!
    Oct 2024
    6
    Re: Help needed using Cimatron 2024's Turing module
    Quote Originally Posted by Xecor View Post
    Hello
    Thank you!
    I'm not really sure about using someone else's machine files as machines can have huge differences in configuration and features, especially if you use a conversion kit.
    Apr 2020
    14
    Gentlemen, help me find the post and machine file for the SMX2100 Doosan turning and milling machine
    nexusmi87@gmail.com
    Dec 2024
    Quote Originally Posted by BSV87 View Post
    fnfnexusmi87@gmail.com
    Please reply if you get help!I have the same question as you.
    Apr 2025
    nexusmi87@gmail.com
    Thank you for updating the information sharing getting over it scratch to exchange knowledge about SMX2100. We will definitely share more issues together.
  1. Vytek FX2 laser module pin connections help needed
    By Chrisviney in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 08-26-2023, 01:34 PM
  2. noob advice needed for selecting laser module
    By HowardTheDuck in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-14-2020, 01:18 AM
  3. Sinusoidal surface diamond turing
    By bezrenki in forum Uncategorised CAM Discussion
    Last Post: 03-07-2017, 05:03 AM
  4. Cimatron E9 file not opening in Cimatron E10
    By vikas123 in forum Uncategorised CAM Discussion
    Last Post: 01-22-2017, 03:24 AM
  5. Arrow CT C80010 Memory module needed
    By Larry Callahan in forum Cincinnati CNC
    Last Post: 12-08-2009, 10:27 PM
