587,204 active members*
3,007 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Help for a new user
    May 2005
    10
    Help for a new user
    hello all
    I continue my appprentissage
    I have a part with two reaming of 20 mm
    diameter and 5 mm of depth
    I make two operation of machining
    1) Surfacing -1mm
    2) Reaming
    how to configure the parameters of the operation
    reaming so that the machining of the hole starts in top of the part
    -1 mm
    Sep 2004
    35
    Visual Mill Training Material
    Mecsoft website has expanded it's training material available online. Several vidos and PDF's of the user manauls.
    Good Luck,
    George Ray
    Sep 2004
    264
    The easiest is probably just to copy the reaming curves and move them down 1mm (Copy, paste, move). Then use the copied curves for the reaming op. VM doesn't have fantastic tools for working with contours (curves) at different depths than where they are drawn, the only other solution I have found is to get out your calculator. --ch
