Hi all its been quite a few years and cnc builds since if been on the forum .I have in a folly purchased a motion control board to try (Novusun NVEM control card )instead of my usual ESS it is -
CNC 200kHz Ethernet MACH3 Card Breakout Interface Board Motor Motion Controller | eBay
I thought it looked easy to set up and install but unfortunately it is proving to be difficult and im hoping someone out there has some information that can help
I contacted the seller at first and they have sent me a manual and a plugin for Mach 3 that I have dropped into the plugin folder
when I start mach3 it asks if I would like to use the novusun plugin and I check the box but it will not jog, I have gone though the set up in the manual, the only thing that I cannot understand is it asks to have to PI changed in the PC if I use a network cable which I am using. What is PI? I assumed it meant IP but where would I put it and the code that is given is strange.
It doesn't seem to see the controller?
Any help would be appreciated
Rod
