603,968 active members*
1,966 visitors online*
Results 1 to 6 of 6
    Jan 2005
    24
    Help picking a Driver
    I'm putting together JGro's CNC Router and I have 3 Vexta motors Model C7463-9212kgm, what drivers do you suggest I get for these? or will any driver work for 6-wire motors? looking for cheap solution if possible, any help would be appreciated. Also is that all I would need, hook the motors to the machine then to a driver then out to a PC and then purchase software?
    Thanks guys, sorry I'm new to all this
    Mar 2005
    116
    Sorry, but since you didn't post the current and the voltage I can't answer you with specifics but you can go to Phil's site at http://pminmo.com and have a look at his boards, they are inexpensive.
    Yoram
    Jan 2005
    24
    im sorry guys, its DC 5.7V 1A 2-phase motors
    Aug 2004
    3215
    I use the Hobby CNC board with my 5.2v 1.4a motors. works really well and is only 79 dollars. But i am interested if http://pminmo.com/ has a board like the 3 axis all in one board, I'm just not surem I would not mind trying to make my own and see a cost comparason
    Mar 2003
    6855
    I have tested both the Xylotec and the hobbyCNC board, and they both work very well. The Xylotec has special circuity that will make it work with "green" computer systems and also has a the ability to unconnect the steppers from from being driven.
    Jun 2003
    3312
    Paul,
    Whats a "green" computer system?
    Phil
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  1. Good driver for Omron U75030VA-BS1 servomotor?
    By Vikketsi in forum Servo Motors / Drives
    Last Post: 02-26-2005, 09:53 PM
  2. servos motor controled by stepper motor driver?
    By mike10 in forum Servo Motors / Drives
    Last Post: 01-04-2005, 12:05 AM
  3. Fun with floppy stepper and driver
    By Konstantin in forum CNC Machine Related Electronics
    Last Post: 03-08-2004, 08:18 AM
  4. Selecting stepper driver components...
    By fyffe555 in forum CNC Machine Related Electronics
    Last Post: 09-26-2003, 03:50 PM
