588,626 active members*
5,479 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Help with planar surface cant get this drawing to work
Results 1 to 4 of 4
    Jan 2013
    43
    For a DXF 2d drawing Is there a way to select a whole object and join gaps? Or do you just have to zoom in and find every little one and use "join line"
    Mar 2012
    1570
    Re: Help with planar surface cant get this drawing to work
    No,
    You need to join where gaps are. Do a chain selection and where the selection stops is your gap. You could join with lines or you can use trim extend.
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Apr 2009
    3376
    To the OP,,the file you had uploaded originally,here it is with planar.
    Jan 2013
    43
    Ok thanks Al, just wanted to be sure I wasn't doing it the hard way
  1. CAM software for drawing on the surface
    By cncspadeto in forum WoodWorking Topics
    Last Post: 10-11-2014, 10:46 PM
  2. Software for drawing on the surface
    By cncspadeto in forum Waterjet General Topics
    Last Post: 10-11-2014, 10:28 PM
  3. drawing on a 3d model surface
    By --> in forum BobCad-Cam
    Last Post: 11-02-2013, 12:01 AM
  4. Can't highlight drawing for inside planar finishing
    By williamsmotower in forum MadCAM
    Last Post: 12-13-2010, 11:36 AM
  5. Replies: 1
    Last Post: 06-20-2008, 08:30 AM
