ok i'm not sure if this a motor driver issue or a software set up issue or the guy wiring it all up lol, namely me....
i have nema 24 closed loop stepper motors which came with the CL57Y drivers, the wiring of the motors is shown on the paperwork which came with the motors, so i'm guessing that is wired fine. the software i am using is UCCNC through a UC400ETH motion controller, into a breakout board.
the UC400 is via ETHERNET cable and a dedicated power supply, the BOB gets power from a USB cable. at present the motor is in a locked state so i guess it has power at least. the BOB has LED's which show power when driven, and do light up in co-ordination with the pin settings in the UCCNC configuration tab. at present the motor does not turn it is just locked, i have a wire to the ENABLE connector on the driver.
the software has a license and is running out of demo mode, when i jog the motor i can see the display show movement but the motor stays locked
any ideas or help would be great
thanks neil
