603,945 active members*
3,906 visitors online*
    Jan 2004
    HELP Please Turbocnc 4 scale
    Hi trying to setup my sherline 5410 mill useing Turbocnc 4
    any one know what size the sherline leadscrew is
    also trying to work out steps per inch for the motion scale calc
    i am running 1.8 deg stepper motors in 1/8 step on controller
    any help would be greatfull
    thanks guys
    :cheers:
    Sep 2004
    80
    Measure the handwheel turns per distance traveled for each head piece if you have wheels mounted. This should get it close. Otherwise I guess contacting sherline for a description of the leadscrews shipped would be the way....
    Apr 2003
    131
    I have heard that the Sherline mill feedscrew is 20 TPI.
    There's a small button that says "Calc" next to the step size in the dialog for axis setup. If you click this, a little window pops up that lets you enter TPI, steps/rev, microstepping, etc and it figures it out for you.
    If you want to do it longhand:
    Start with the number 1.
    Divide by TPI (20?).
    Divide by steps/rev (200)
    Divide by microstep ratio (8)
    Divide by gear ratio (1 for no reduction)
    So about 0.00003125" per step or so...
  1. turbocnc and cams gcode
    By Lu_ca in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-12-2006, 12:50 PM
  2. Help setting up turbocnc 4.01..??
    By lurch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-07-2005, 09:57 AM
  3. RFQ closed - scale model machined auto wheels needed
    By joemartins in forum Employment Opportunity
    Last Post: 10-27-2004, 02:16 PM
  4. Is it my computer or Turbocnc?
    By wjbzone in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-10-2004, 11:58 PM
  5. Very Basic Scale DXF Question
    By awm in forum BobCad-Cam
    Last Post: 01-07-2004, 05:11 PM
