587,837 active members*
3,431 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Help with producing a 3D toolpath
Results 1 to 12 of 12
    Jul 2003
    138
    Hello, can someone please help me to produce a simple 3D toolpath.
    I have attached the file of the part I have created and I am having trouble producing the surface rough and finish toolpath for the slope.
    Any help would be appreciated.
    Thanks… Norman
    Attached Files Attached Files
    Sep 2005
    19
    How do you want to machine it. What tools do you want to use , and what Material .what size rd In the Cornor of the slop . what controle . let me know iI will help
    May 2005
    94
    First off, do you have a model that contains surfaces or solids?
    If your not very familiar with surface toolpaths, I'd recommend surface>finish>parallel for the inclinded surface. As for the wall, that may take some monkeying around with. Surface>finish>contour will scrape the wall, while possilby pencil trace will finish the crotch.
    With surface paths, there are always a number of differnt ways to skin the same cat. Some work better than others, sometimes you've just gotta experiement.
    Jul 2003
    138
    Thanks for everyone’s help thus far.
    I have a small bench top CNC mill (TAIG), the material will aluminum and I will be using a 1/8” flat end mill. I can buy a round end mill if required.
    The radius of the inside corners can be that of the end mill.
    Dec 2005
    31
    Er, I made a solid and I have it in mastercam X.
    Would you like me to simply post it out for you or would you like my solid/mastercam file?
    if you want me to post it out, what do you want for a stepdown on roughing, and a stepover for finish along the cut?
    http://smackaay.com
    Visit my site
    Jul 2003
    138
    Thanks Tarkus.
    I would prefer it to be in a MC9 file so I can load into Mastercam V9 and generate my own post file.
    With respect to stepdown and stepover parameters, can you please make a decision for me based on my use of a small TAIG (benchtop) mill and 1/8" end mill.
    Norman
    Dec 2005
    31
    I'll do it in mastercam 9 then... I'll be a little while longer, have to go use my laptop.
    http://smackaay.com
    Visit my site
    Dec 2005
    31
    Here you go man, it should work... I would've been done sooner but I don't have MC9 on my work machine.
    Tell me if it works for you.
    http://smackaay.com
    Visit my site
    Jul 2003
    138
    3D Toolpath
    Thanks for your time Tarkus, the file worked great!
    Dec 2005
    31
    You know though, if the part looks like the solid you sent, it would have been faster to simply blank out the 2x4x.5 blank and cut the angle from the side...
    http://smackaay.com
    Visit my site
    Nov 2005
    174
    why not just save it as an mc9 file then email that to him.
    Apr 2003
    3578
    Here is a sample of your file with tool paths and no surfaces or solids.
    using 3d contour and A Wirefram toolpath called Ruled.
    This all can be done with a Level 1 of mastercam
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
