588,548 active members*
5,774 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Help for programming NPT threads.
Results 1 to 1 of 1
    Mar 2003
    2932
    I've seen enough questions up here about programming NPT threads that I thought maybe I could do something help.
    This little program will create code for Fanuc (2 and 1 line), Yasnac, and Haas G76 cycles. It's beta software, so if you use it, BE CAREFUL... NO GUARANTEES!
    Let me know if it works, doesn't work, helps, doesn't help, what it does wrong, what it does right. All comments and suggestions are welcome.
    Thanks for your time.
    Attached Files Attached Files
  1. Help for programming NPT threads.
    By dcoupar in forum G-Code Programing
    Last Post: 04-03-2010, 09:07 PM
  2. NPT threads
    By mbm in forum Okuma
    Last Post: 03-24-2010, 04:40 PM
  3. Different threads
    By johngo1 in forum Machines running Mach Software
    Last Post: 02-18-2008, 11:29 PM
  4. Cam Programming On ID 1/2-14 NPT Threads
    By Josh-PTP in forum Uncategorised CAM Discussion
    Last Post: 02-28-2007, 01:10 AM
