603,546 active members*
3,114 visitors online*
    Jan 2024
    Help with programming a radius in XZ
    Hey, I'm using heidenhain and I'd like to ask if I can make a radius in the XZ axes somehow. For example the mill will go down at x0z0 and reach its peak at x2,5mmZ-2,5 and goes back to X5Z0. Sorry if it's a dumb question but I'm new to this
    Mar 2015
    53
    Re: Help with programming a radius in XZ
    Greetings,
    Rather than trusting my poor memory, read up on G18 and G19 codes. One is for XZ moves and the other for YZ moves.
    G17 is, generally, the default machining plane (XY).
    Remember to switch back to G17 after your XZ circular interpolation moves.
    Cheers,
    Dave
  1. Programming radius
    By Tyg in forum Haas Lathes
    Last Post: 12-02-2023, 06:23 PM
  2. PROGRAMMING RADIUS
    By nathanokkema in forum Okuma
    Last Post: 10-02-2023, 01:40 PM
  3. programming a radius
    By honda27 in forum G-Code Programing
    Last Post: 10-31-2008, 02:25 PM
  4. Programming a radius
    By fukeneh in forum G-Code Programing
    Last Post: 07-14-2007, 03:35 AM
