603,379 active members*
3,644 visitors online*
    Mar 2017
    Help with Rabbit cutter plotter
    I am having trouble with my Rabbit cutter plotter. I need advice on how to get it to communicate with my computer. It was running fine with Flexi software until when I was cutting vinyl and it rolled off, I hit pause on the cutter, then took the vinyl out, then turned the power off. When I turned it on again, it carried on its cutting mode until finished. But now I can not send anything to the cutter to make it cut. The cutter seems to have an internal memory that stores cut files sent to it, as sometimes when I turn it on, it starts cutting a previous file I sent to it. I have pushed the Reset button many times to try and clear the memory, or whatever is stopping it cut when I send the file from Flexi, but nothing works.
    Can anyone help with advice on how to clear the memory in the cutter, or reset it so it cuts like it was doing before I hit the pause button and messed it up?\
    Jan 2021
    Unhappy Re: Help with Rabbit cutter plotter720
    can any one help me with is i just got thi Rabbit cutter plotter720 but o dont have the drive any any thing can some one plz help me with is
  1. Using Rabbit 800 as a pen plotter
    By xairflyer in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 02-11-2013, 06:12 PM
  2. flatbed cutting plotter,cutter plotter
    By huiteng in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 01-23-2013, 09:42 AM
  3. Rabbit Plotter Error Half Way Through Plotting!!
    By jimsmith in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 06-13-2012, 05:24 PM
  4. Rabbit hx 800 cutter/plotter
    By riaandames in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-11-2011, 01:00 PM
  5. Need help with RABBIT vinyl plotter
    By hodge98ws6 in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 05-12-2010, 02:30 AM
