the spinner is built in softoware shopmil ,when i try to command tool change the machine wont recognise the command t2m06 on mdi panel ,whats wrong with it can somebody help me .?when i in the shopmill it accept the tool change..why?
pls... send instruction or something to change in the parameter..step by step send it to
[email protected]
Your machine is probably set up to use tool names not tool numbers as your ATC will relocate tools into different pockets everytime you change tool. Hence numbers won't give you same tool each time.
Try:
N10 T="toolname" M06
N15 T="next_tool_name"
*PROGRAM*
M32
* N15 line optional for preselector, will not change to tool until next M06 but will line up ATC, Don't forget to apply tool length comp. if you are coding a full program not just changing tool.
Other way to change tool is to press <JOG>, <T,S,M>, <Tools>, select tool, then press <In Manual> then <Cycle Start> - That should load the tool into the spindle.
HTH
John
