603,365 active members*
4,095 visitors online*
    Jul 2022
    Question Help! - Rotary Tube Plasma Cutter Build
    Hi All,
    I'm new to this forum so I apologize if I'm posting this in the wrong place, let me know and I'll move to the appropriate forum.
    MACHINE DESCRIPTION
    I'm currently in the process of designing and building a rotary tube plasma cutter. More or less a copy of this machine: https://www.youtube.com/watch?v=xMb9XZjK6m0&t=56s
    Main differences are that I don't intend on having multiple tool heads (the A-400 has an engraver, pan marker & plasma torch) I only want the plasma torch. I also won't be including the automatic material support along the X axis.
    I have the layout and hardware sorted out, X axis carriage carrying a 4 jaw chuck for the A axis rotary, then Y & Z axis carrying the torch on the front face of the machine. I'm using nema 34 motors for the carriage and rotary, then nema 23's for Y & Z (May be undersized, but will find out the hard way). I have limit switches at each end of each axis & emergency stops on the carriage and front gate.
    THE ACTUAL QUESTION
    So I believe I have the basic hardware components of the machine sorted, now I just need to settle on motion control and interfacing with plasma unit itself.
    I will be running a Hypertherm Powermax 65 and THC is a must when cutting 3D shapes.
    I'm currently using Mach3 as a controller hooked up to a generic 4axis motion control board sending signals out to my stepper drivers. There is currently not interface with the plasma at all.
    So I suppose my question is 3 parts;
    1. What motion controller should I be using?
    2. What motion control board should I be using?
    3. How can I interface my controller with the plasma for gas flow monitoring and arc/TH control?
    DISCLAIMER
    I'm fairly new to CNC and electronics, I'm a boilermaker by trade and have experience operating CNC equipment but this is my first time building a machine from scratch. I therefore apologize if my lingo and terminology is incorrect, I expect may be able to better frame my questions as my CNC understanding & vocabulary grows. Please correct me where I need to be correct.
    I look forward to your response,
    Drew
    Jun 2007
    75
    Re: Help! - Rotary Tube Plasma Cutter Build
    No reason at all you can't keep using Mach3. You might want to upgrade the control board to a smoothstepper though. I had lots of issues with direct parallel port control because timing variations on a stepper motor cause it to lose torque and sometimes slip poles. A rotary tube cutter should not require THC because the distance to the cut never changes as the tube rotates. (Edit: my last statement is only true for round tubes, but Mach3 has ability to utilize THC)
