603,850 active members*
4,476 visitors online*
Results 1 to 1 of 1
    Dec 2018
    4
    Smile Help SCM Tech PLC problem
    Hi !!! the computer ( Esa kvara 30) in my machine (scm 95 tech L )has been damaged. I bought the same but not with scm only with morbidelli. when connected, it shows errors
    I do not have floppy disk with files
    how to fix it ?
    I am a student I can not afford a scm service
    thanks for the answer
  1. Need a low tech solution to a high tech problem (kind of urgent)
    By PeliTac in forum Want To Buy...Need help!
    Last Post: 01-23-2014, 05:05 PM
  2. tech 99L scm problem with control schematics
    By chrisilias in forum CNC Machining Centers
    Last Post: 11-22-2012, 10:35 AM
  3. SCM Tech 95 L controller problem
    By Arttu in forum Commercial CNC Wood Routers
    Last Post: 02-12-2011, 10:15 AM
  4. Okuma Act-3 Servo Problem, Tech wanted
    By KE4GHC in forum Okuma
    Last Post: 03-11-2009, 04:02 AM
  5. Ultimate Tech Problem Solved!
    By shootingarts in forum DIY CNC Router Table Machines
    Last Post: 01-01-2006, 05:58 AM
