588,563 active members*
5,017 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Help with selecting drivers/breakout boards
    Apr 2012
    4
    I am in the process of putting together a DIY CNC Router. I just purchased 3 used MCG IS34027 NEMA 34 650oz servo motors. Unfortunately, I have not found a wiring diagram for these motors. The motors are I believe 8 wires. I need to purchase drivers and breakout board as well as power supply that will work with these motors. Anybody have any suggestions on what might work with these motors? Sorry for being so ignorant on this, but hopefully, someone on this forum can steer me in the right direction.:drowning:
    Jul 2011
    It depends on your knowledge and experience.
    I would rather buy a kit, motors driver boards and power supply from a vendor which will help you with the set up.
    The motor number typed in google comes out on top of the search.
    http://www.alstron.com.sg/Motor_MCG/PDF/IS34027.pdf
  1. Open Source Boards Available, Stepper Drivers and Break Out Boards
    By pminmo in forum Open Source Controller Boards
    Last Post: 06-23-2018, 01:46 AM
  2. breakout boards
    By daniellyall in forum Stepper Motors / Drives
    Last Post: 04-14-2012, 01:34 AM
  3. CNC4PC Breakout Boards
    By Degrom in forum CNC Machine Related Electronics
    Last Post: 01-31-2009, 12:52 AM
  4. Breakout boards
    By DaPyro in forum CNC Machine Related Electronics
    Last Post: 06-23-2006, 07:22 PM
  5. breakout boards
    By Gads in forum CNC Machine Related Electronics
    Last Post: 03-06-2006, 12:39 AM
