Hello everyone, I'm new in SolidCAM and have a question and safe for you is easy, I want to use an engraving tool 0.1mm and selecting a speed of 20000rpm I get this error, as I can fix this?
please see the attached image.
Luis
Luis
You'r machine can rotate that much?
Arikaa, I mean speed of the spindle is 2.2kw to 24000rpm , I have to mention that I am a novice in SolidCAM, so I need help
Open the machineID file and change the RPM to 24000
thanks you, I've got a video on your feedback https://www.youtube.com/watch?v=g0Rt-072Hr0
Now I have to find that post processor is compatible with my Chinese machine:drowning:
Hello everyone, I have a new problem emerged, I tried to make the paths by selecting the generic post processor fanuc.
I have an error this file is missing gMill_Generic_Fanuc_X_4x_Eval.GPP(check the image), please kindly someone can send me ?, thank you very much.
By default the gpp file is located in C:\users\public\public documents \solidcam\solidcam2015\gpptool . Check whether the file is there or not ! If the file is missing then just reinstall the post processors
I've looked but not found in the picture looks, my version is 2014, please can you share
Hey,
you have to put postprocesors to that location
C:\Users\Public\Documents\SolidCAM\SolidCAM2015\Gp ptool
and then set in solidcam settings -> Default CNC-Controler , then in first row you find that location and confirm it.
You have to have 3 files for one machine with next extentions ( .GPP .PRP .vmid )
hi here is the files good luck!
Thank you very much for sharing this file :cheers:
hey bro i need those 3 files
.gpp .prp .vmid for my siemens 828d controll for solidcam
plz help
if u can send me the post processor file i shall be thankful for that
my email is [email protected]
