603,310 active members*
2,430 visitors online*
IndustryArena Forum > MetalWorking Machines > South Bend Machinery > Help with South Bend Magnaturn CNC lathe
Page 1 of 2 12
Results 1 to 20 of 30
    Mar 2003
    66
    I have a South Bend Magnaturn CNC lathe that I want to get up and running. I have split off the single phase computer components and am running the 3 phase components from a rotary converter. I can get the fans to run, but nothing comes-up on the screen. I have tried a different monitor and it seems that I am not getting anything to the monitor. I can hold-in the magnetic contactor and get the blower and hydraulic pump to run. Does anyone know anything about these lathes? How about somebody that I can talk to? I don't want to have to pay BIG BUCKS for a service guy, but if I have to then I will. How about a retro-fit?
    Thanks,
    Scott
    Sep 2004
    240
    Hi, Do you still have your magnaturn lathe?
    Mar 2003
    66
    Yes, I do still have the lathe.
    Thanks,
    Scott
    Sep 2004
    240
    Hi, I was wondering how the project come out. Did you do a retrofit? I have a
    Magnaturn 612. I was hoping for pictures posted of you machine. I have mine posted under MechMan.
    Jul 2006
    4
    What model is it?
    We run them here.
    Jim
    Sep 2004
    240
    Red face
    Hi, I have the Magnaturn 612. It was designed to be run from 115 VAC single phase from day one. I would think setting your up to do the same would be fairly easy. The real question is was yours complete? I ended up having to purchase the PC Card and software from Southbend. Not Cheap. There is one other thing I need to purchase for mine that will have to wait until I have the funds. They offer an additional program called Ultrapath that requires a printer dongle to unlock. This program provides the toolpath graphics. Big drawback to my machine is there is little tooling available. You can see mine in my gallery. I was one of the top posters if you go to the gallery page. :violin:
    Jul 2006
    4
    We use 1218's in production turning with barfeeds.
    A couple of the machines even have Ultrapath, though nobody here has bothered to learn a new CAM package that is limited to one brand of lathe.
    We usually program off-line in either MasterCam or straight G-code and use a
    utility that came with the machines to upload the ASCII files into their own language.
    South Bend talks about importing a Taiwanese machine to get back into CNC, not realizing that users like us will just buy Taiwan machines directly from the Taiwanese if we wanted them.
    Sadly South Bend, like what little else remains from the American machine tool industry, survives by overcharging for spare parts.
    Sep 2004
    240
    Your right, it's sad considering CNC technology was developed in the United States. If you ever decide to sell one of the Ultrapath printer port dongles let me know. I would be interested. I'm proud of my little machine. It so rare that you find American CNC Iron. MechMan
    Mar 2003
    66
    I replaced the computer with an old 286 that I had and the machine runs. I have two other CNC lathes and have not put the time into learning the South Bends Ultrapath. I did hear of writting standard G-code and sending it to the machine, but have not tried it.
    Thanks,
    Scott
    Mar 2006
    6
    Anyone have manuals, wiring Diag.s, software, for the 1218 magnaturn.
    If so email me at [email protected]
    Thanks, Chip
    Florida
    Sep 2004
    240
    Hi, The 1218 is a different animal than the 612. The 612 is a very small machine. Manuals for your machine may be available from Southbend. I paid I believe $60 a piece for the two manuals that were available to me. SouthBend wouldn't release the board level repair manuals. The software is also exclusive to the machine. Those are closed loop machines and travel paramiters are designed into the software. The software is not cheap. I was close to doing a retrofit myself. If it were not for the closed loop quality I would have done it. The only thing the two machines may have in common is the PC control card. I only have the one. If you decide to retrofit let me know if you decide to sell that card. MechMan
    Mar 2006
    6
    Thanks for the fast reply,
    Just fired up the lathe, cpu powers up have F1-F10 keys on bottom of screen, save,load run ect....., start button / other swiches have no effect.
    This is an early 1200 series sn00039 I think, Holding Hyd-Contactor in, spindle turns, X appears to home.
    Looking for diag pin-outs not board level, just basic diagrams, considering retrofit unless I can find software, Just trying to find a starting point hear.
    On your lathe is there a (software) disk that enables front panel switches / controls.
    Thanks, Chip
    Dec 2005
    120
    I have two of the 1218's. Used them for years. Typically run
    G code programs. I have the operator manuals and assembly diagrams with wiring schematics (not board level). They are pretty easy to figure out. Hydraulic with sony magnetic scales. Dont know if you guys know the trick about converting your programs to metric. Its a function in the software. You can get a bit more precision that way. Just rebuilt the spindle on one. Going through them now, going to sell them both.
    Mar 2006
    6
    Hi, Sprew
    Thanks for the Info.
    Went to the shop this afternoon booted computer from disk, Dos ver. 3.31 all went well formated 2 disks A and B drives seem fine.
    Looking for an old plugin Hardedrive its around hear some where, may have a later ver. of dos around hear also.
    Found one card (Axis Control Board) with a Cap and
    Xtal 1 broken off, have it hear at home fixing it now.
    Thanks again for the Help, Chip
    Mar 2006
    6
    Hi, All
    Looking for a copy of SBLLATHE.EXE file for my 1218 lathe, have an early S-number with old stile tool changer encoder, haven't figurd out how to configure the CNC303A.EXE software for it.
    Unable to get it from SB, the 600 series file may work also.
    If someone can help, Zit it up and email to [email protected]
    Thanks, Chip
    Jun 2007
    Executive disk Magnaturn 1218
    Hello afn09556
    I have a 1218 but no Exective disk and the SBLLATHE.EXE disk is bad. When I power it up, no screen comes up. South Bend Lathe has no disk replacement. Can you help. Thanks clif
  17. #17
    Sep 2004
    240
    Magnaturn
    Hi Clif,
    I have a 612 and it is a whole different animal. It's a stepper controlled machine and the travel parameters are different. The software I have wouldn't do you any good. Last I heard Southbend technical supoort is retired. Southbend probably doesn't hold the right to sell the software for those machines any more. I had a contact from the software developer. It may be in the post. They could probably help you. You might want to consider a retrofit. If it were not for the closed loop quality I would have retrofitted my own machine. A retrofit will get you some real speed. I recommend Flashcut. MechMan
  18. #18
    Oct 2007
    11
    I have a magnaturn 612, I need software and comunication card, I buy a copy of the software and a card or another solution.
  19. #19
    Oct 2007
    11
    Can you sell a copy of the magnaturn 612 software call me at 915-694-5898 or put the phone number an I call you
  20. #20
    Jul 2006
    4
    We only have 1218's. I understand the 612 to be completely different.
Page 1 of 2 12
  1. Just got a South Bend Magnaturn 612
    By USN in forum Benchtop Machines
    Last Post: 11-17-2013, 01:39 AM
  2. Anyone know the South Bend Magnaturn 612?
    By dcencer in forum Controller & Computer Solutions
    Last Post: 11-23-2012, 04:18 AM
  3. MagnaTurn South Bend Lathe Set Tool Offset
    By CNCbad in forum Uncategorised MetalWorking Machines
    Last Post: 05-26-2011, 07:03 PM
  4. WTB South Bend Magnaturn
    By Artty62 in forum Want To Buy...Need help!
    Last Post: 02-22-2011, 10:54 PM
  5. South Bend Magnaturn 612
    By htral in forum Uncategorised MetalWorking Machines
    Last Post: 07-23-2008, 05:14 PM
