603,975 active members*
3,240 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Help with a strange key combo that causes rapid move- dangerous..
    May 2007
    327
    I use shift + pg up or shift + pg dwn to often move the z axis quickly into position. But there is another key combination that I hit by acident sometimes its cntrl+pg up or down. (i think)
    this is the problem the mill moves about 4 inches in whatever direction when that key combo is hit, no way to stop it, this has broken a couple things.
    is there a way to disable this? or what is this key combo about. its a real trap hitting that by accident since the shift is near the key.
    thanks
    Dec 2003
    24
    ctrl + page down or up or arrow keys
    ctrl + page down or up or arrow keys are for jog for set distance.
    you can change incremental jog distance from page which appears after you press tab key.
    axis moves at jog speed which can also be changed from same place
    Regards Mika
  1. Rapid move axis control
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2008, 03:51 PM
  2. Is this dangerous?
    By QSIMDO in forum Phase Converters
    Last Post: 04-07-2008, 10:29 PM
  3. Haas rapid move ?
    By binzer in forum Haas Mills
    Last Post: 06-29-2007, 01:11 AM
  4. Crash during Z rapid move
    By AndyB in forum Fadal
    Last Post: 03-07-2007, 03:48 PM
  5. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
