588,182 active members*
4,009 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Help..taper correction and g75/g76...
Results 1 to 6 of 6
    Jul 2007
    72
    Z.01 F.002
    G75 X=V2 L=-CH1
    G76 Z=-V10 L=CF1 F=FF
    G75 X=V3 L=-CH2
    PD=V3
    IF [V4 EQ 0] N12
    G76 Z=-V10-V11 L=CF2
    G75 X=V4 L=-CH3
    PD=V4
    N12
    IF [V23 EQ 0] N14
    G1 Z=-DL+.00
    G1 X=PD-.050 Z=-DL-.04 F.002
    GOTO N16
    I was hoping if I added a X value into the g75/g76 lines I could get taper correction. but that messes up end/start points so I cannot do this.Is there a simpler way than inserting a line between the g75 and g76 that would contain the end point/start point of consecutive g76/g75 commands?:banana:
    CHEERS!
    I'm just a butcher masquerading as a machinist
    Apr 2009
    1262
    it is possible to add an A command to the G75/G76 line which defines an angle, but getting your results may be difficult.
    Best regards,
    Jul 2007
    72
    kewl beans...I didn't know about A
    think I'll try
    g1 X..Z-R..A..
    g3 Z..L=R
    but I will test out A in G75 1st A=180-ATAN[dif dia/length]...or something
    CHEERS!
    Apr 2009
    1262
    Quote Originally Posted by gogego View Post
    think I'll try
    g1 X..Z-R..A..
    g3 Z..L=R
    CHEERS!
    Won't work like you are thinking in G1 G3 lines since they already have XZ positions and it would conflict. Will work with G1 Z-1 A-.001.
    Best regards,
    Dec 2008
    3136
    Why not use the maths function to eliminate the taper
    - just re-state the X size at the end ( the endpoint having the taper cancelling value )
    Code:
    Z.01 F.002
    G75 X=V2 L=-CH1
    G76 X=[V2+0.0020] Z=-V10 L=CF1 F=FF
    G75 X=V3 L=-CH2
    PD=V3
    IF [V4 EQ 0] N12
    G76 X=[V3+.0020] Z=-V10-V11 L=CF2
    G75 X=V4 L=-CH3
    PD=V4
    Apr 2009
    1262
    You can't use X,Z And G75/76 in the same line without getting an alarm.
    Best regards,
  1. G42 correction problem
    By pit202 in forum Haas Lathes
    Last Post: 05-21-2009, 02:31 PM
  2. Correction question
    By majstor76 in forum G-Code Programing
    Last Post: 02-13-2009, 11:02 PM
  3. G-code for a correction
    By seunao in forum G-Code Programing
    Last Post: 12-10-2008, 02:29 PM
  4. Taper correction help
    By OKThumper in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-27-2007, 01:32 AM
