587,744 active members*
2,700 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Help with Tapmatic Tapping Head - Denford Triac - Mach3
Results 1 to 6 of 6
    Oct 2012
    33
    hi all,
    im new this is my first post.
    i own a denford triac vmc with 6 station tool changer. the machine has been converted to run on mach3.
    today i received this bad boy -
    Tapmatic BT35 N/C-R Tapping Head | eBay
    not got a clue how to use it, i cant even find a manual for it online.
    can anyone offer any help on how to get up and running with it?
    Dec 2003
    24220
    Albert E.
    Apr 2006
    3206
    It'll tap between a #4 (like a 4-40) and a 1/4-20 thread. It should have come with at least 1 rubber collet (for that range you really need 2).
    It'll run up to 3000rpm
    Stick your tap into it, tighten it with the 2 flat wrenches that should have been provided.
    Run it down as though you had a tap in a drill chuck... but keep in mind that the tap will continue down after the head stops its -Z travel. The tap will continue down until it releases inside the head, then while the spindle continues to rotate, the tap will stop turning. .... You'll need to experiment to see what that overtravel distance is for YOUR head..... Just think of this thing in terms of rigid tapping.
    When you retract the head (at the same rate you fed it in) and the spindle in reverse, the tap will re-engage internally and begin to back out of the hole.
    The side lug is to keep the head from rotating, so you're machine will need to accommodate it.
    Do some test holes with it.... in some 1/4" thick AL,,, with a 1/4-20 tap. Drill some .201" holes and tap 'em with the material clamped in such a way that you can see the tap go thru, and see how much further it goes after the Z travel of the head stops.
    Tapmatic heads are wonderful creatures! ...
    Oct 2012
    33
    ok maybe i should have explained slightly more.
    i understand how to use a tapping head and what it does, but i dont know how to use it with my machine
    im assuming i would need some special code setup in mach3?
    Apr 2006
    3206
    Quote Originally Posted by andy_con View Post
    .."not got a clue how to use it, i cant even find a manual for it online."
    ok, maybe I should have explained a lot less.
    Oct 2012
    33
    Quote Originally Posted by fizzissist View Post
    sorry im not being clear.
    i understand the principles of what a tapping head does and how it works, but ive never actually used one so dont know how to use it
  1. Wanted Denford Triac CNC Mill
    By angusnoble in forum Want To Buy...Need help!
    Last Post: 02-06-2012, 01:17 AM
  2. Denford Triac spindle drive
    By Jimthefish in forum CNC Machine Related Electronics
    Last Post: 04-01-2010, 11:01 AM
  3. Denford triac help
    By Jimthefish in forum Stepper Motors / Drives
    Last Post: 03-30-2010, 11:11 AM
  4. Denford Triac VMC ? Any experience?
    By dfstrasser in forum Benchtop Machines
    Last Post: 06-18-2007, 09:15 AM
  5. How to use this Tapping Head (Tapmatic?)
    By saris in forum MetalWork Discussion
    Last Post: 11-21-2006, 04:08 AM
