603,940 active members*
2,308 visitors online*
Results 1 to 16 of 16
    May 2005
    62
    Help with threading
    I need to cut some 2"- 4.5 TPI thread on 1018, 6.5 inches long. I'll be using a high speed tool for the first one and when the brown truck comes I'll be using an insertable carbide tool. I have a Fanuc 6-T control. What G-code should I use? An example would be great. The manual says G92 is the canned cycle for threading, but I can't understand how to write it. I could use G28, but that would take forever to write. What RPM and depth per pass should I use for each tool? I have only cut threads with a manual lathe. What infeed angle will this machine use? Thanks for any help or suggestions.
    Jan 2006
    4396
    Quote Originally Posted by protrxrptr17 View Post
    G92 is a good Canned Cycle but you may want to use G76 instead.
    G28 is a Home Position Return example home X and Z
    G28U0W0
    G92 goes like this. It is a little long because the Material was Inconel X750
    G0G40G80G97G99M5
    G28U0W0M9
    G50S2000M41
    M1
    N1(THD .5 20 UNJF-3A KENNAMETAL)
    T0707 S1000 M13
    G0 X.75 Z.08
    X.62
    G92 X.496 W.22 F.05
    X.49
    X.484
    X.479
    X.474
    X.469
    X.464
    X.46
    X.456
    X.452
    X.449
    X.447
    X.445
    X.443
    X.442
    X.441
    X.44
    X.4395
    X.4395
    X.439
    X.439
    G0 X.52 Z-.0167 S2500
    G1 U-.12 W.06 F.0008
    G0G40G97Z.1M9
    G28U0W0T0700
    M1
    G76
    X= the minor diameter of the thread
    Z= the length of the thread plus deceleration distance
    I= taper from start to end radially {Tapered NTP Threads}
    K= depth of the thread = D major - D minor / 2] D [depth of the cut on the first pass
    F(E)= the thread lead {F has 4 place decimal programming}{E has 6 place decimal programming} EX. F.0001 E.000001
    A [the angle of the thread normally 30,55, or 60 degrees]
    G00 will cancel both G76 and G92 Threading Cycles.
    Here is a good rule of thumb. Take the same Depth of Cut with your CNC that wou would on an Engine Lathe. That is a Nasty Large Thread that you have to cut in 1018. Speeds are going to be relative to the Setup Rigidity. The Feed will be the Thread Lead so that can't be changed. The Lead on that thread is F.2222
    I would use E.222222
    1018 CR is gummy and tears. It is difficult to get a good finish without using Cermet Inserts like Seco Carboloy FF1's
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    May 2005
    62
    Thanks for the example. What about infeed angle? I don't remember what inserts I ordered, but I think it required a 29 degree infeed angle. On my old manual I took about .020 at first and then backed it down as I got deeper. What RPM sounds right for that? The bar is 40" long and it's just going to be chucked.
    May 2005
    62
    Can you suggest a better material for this? They are essentially just big bolts. 6.5 inches of thread on one end and just enought to thread anut on the other. Then I weld the nut on the short end. I make 2 about every 3 months for a local lumbermill. They break them somehow?? I don't really want to make them any stronger because I want to keep making them. They specified 1018 the first time I made them. I guess they are kind of like shear bolts. Maybe something easier to thread but with the same strength.
    Jan 2006
    4396
    The infeed angle is set by the G76 Canned Cycle it is a little difficult to explain without a drawing.
    I'll post an example Picture for you.
    RPM I'd start at 300 to 600 RPM and use G97S300M3. G97 is Constant Surface Footage Cancel. You don't want your RPM going up when threading or drilling for that matter.
    In this picture the first depth of cut is RED and the Rest are Green.
    Toby D.
    Schwarzwald
    May 2005
    62
    Quote Originally Posted by tobyaxis View Post
    I should have been a little more specific. Is the infeed angle automatically instated? If so, how can I know what it is? I sure appreciate your help. This forum and it's people a a very valuable tool for me.
    Jan 2006
    4396
    1018 Cold Rolled is pretty damn strong. Keep making them LOL. It pays the bills. They want 1018, they get 1018. Pray that your customer doesn't ask for 17-4ph Stainless Heat Treated 45Rc. Or worse yet 13-3ph Stainless.
    Toby D.
    Schwarzwald
    Jan 2006
    4396
    G28U0W0
    G0G40G80G97G99M5
    G28U0W0M9
    G50S2000M41
    M1
    T0707 S1000 M13
    G0 X.75 Z.08
    X.62
    G92 X.496 W.22 F.05
    X.49
    X.484
    X.479
    X.474
    X.469
    X.464
    X.46
    X.456
    X.452
    X.449
    X.447
    X.445
    X.443
    X.442
    X.441
    X.44
    X.4395
    X.4395
    X.439
    X.439
    G0G40G97Z.1M9
    G28U0W0T0700
    M1
    G76
    A is the angle 30,55,60 degrees
    K is the first Depth of Cut
    G76X1.8528Z-6.0K.0721A60E.222222
    The in Feed as you call it I don't think matters. A is the Included Angle of the Thread 60 Degrees
    Attached Thumbnails Attached Thumbnails 2 inch 4 and a half thread MHB 26th.jpg
    Toby D.
    Schwarzwald
    Nov 2006
    31
    A 2" x 4.5 tpi needs about 25 passes to produce. If using only the G92 cycle then the depths would be 0.016, 0.012, 0.011, 0.009, 0.007, 0.006x2, 0.005x3, 0.004x7, 0.003x7 & 0.002. I would use both cycles first a G92 then the G76 something like this.
    G92 X1.968 Z#### F(E)0.222
    G76 X1.732 Z#### K0.134 D28 F(E)0.222 - D = Total depth 1st +2nd depth
    The G76 cycle will take 23 passes plus 1 for the G92 = 24 passes. If you try the G76 ONLY with this depth of cut there is a good chance the tool will break hence the first pass with G92.
    May 2005
    62
    Well, it didn't go to well for me today. I kept on chipping inserts. I tried 175 RPM all the wat to 600 RPM. Chatter was also a problem. I used a Kennametal NSR-164D and Interstate ITN-52004J inserts. I even tried going only .002" per pass and then dropping to .001" as it got deeper. That is with diameter programming, so it's really half that. I think it has something to do with the infeed angle because the chatter marks were on both sides of the thread. I think the tool was feeding straight in. I used G92. I never tried G76.
    May 2005
    62
    Toby, after carefully studying your post again, I see what you were trying to tell me. I will try G76 and see if that works. Is there a parameter to change the angle on G90? It would be just like changing the angle on the compound slide on a manual machine.
    Jan 2006
    4396
    One thing you have to get used to on CNC's, there is no Compound and no way to Change the Infeed Angle.
    Select a C7 Grade of Carbide Insert. It is Tougher than C2. C2 will chip very easily. Call Kennametal on the phone and tell them what your cutting. They will be able to select a Carbide Grade that will suite your needs.
    BTW: You maybe better off using G92 because it allows you to Taylor Each Depth of Cut you make. Use Cutting Oil to. If you were getting Chatter your RPM was too High or the Tool had too much surface contact. 2 thousanths Depth Cuts should do the trick combined with a Lower RPM. BTW put the Spindle in Low Gear Too.
    Toby D.
    Schwarzwald
    Jul 2005
    12177
    Can you suggest a better material for this? .... They specified 1018 the first time I made them. I guess they are kind of like shear bolts. Maybe something easier to thread but with the same strength.
    I can suggest a better material for threading C10L14 leaded steel. It is about the same strength as 1018, possibly a tiny bit less and it is a charm to machine. I suggest you get some and do some trial runs. You might find it so much easier and quicker you can give them a sample and maybe offer a little discount if they switch. It almost certainly will not last longer than 1018.
    You will run into people who claim leaded cannot be welded but it can be provided you use low hydrogen rods for stick welding or use MIG.
    Feb 2006
    1792
    ...G92 X.496 W.22 F.05...
    Are you threading from left to right? Or, have you missed a minus sign with W?
    May 2007
    1003
    First, do you have a tailstock? It would be a big help in eliminating chatter. Chatter is hard on carbide.
    In Tobyaxis G76 cycle, I think the A60 is the compound infeed. At least it is on the only 2 machines I have every seen it used on. Obviously I'm not familiar with many machines using this particular canned cycle. A60 provides the least amount of tool pressure as it is cutting on one side only, the leading edge. Some times this helps eliminate chatter. Other times putting a load on the insert helps. Trial and error.
    I haven't used the G92 threading cycle in so long I can't be sure of exactly how it works. However it is my opinion that it does NOT use compound infeed...at least not as shown in the examples. This zero infeed is one of 6 options on the 2-block G76 cycle (and naturally can be used on the 1-block cycle). Be aware that it creates a chip of equal thickness on both sides of the insert. It is a very tough chip. I've only used it on one job with good results in over 20 years. It was a VERY coarse thread on a VERY small diameter, and was the only way I could avoid chatter. Also used VERY few passes to do it.
    Can you use a G32 threading cycle? Some older Hardinge lathes call it G33. Same thing. You can program any compound infeed you want with these cycles. Much easier to control the depth of each pass than with a G76 cycle. I often have to lie to the G76 canned cycle if having problems chipping inserts. As an example, thread height may be .05, but I might program it as .06 and use a heavier initial pass than I normally would in order to keep the number of passes within reason. (Actual cut would still be less than for the .05 thread height.)
    It's been a while since I've run any 1018 material, but I remember it as being easy to machine. Not as easy as say 12L15 or 11L14, but still very easy. Your biggest problem is the length of the part. A tailstock would solve that problem.
    Feb 2008
    40
    60. angle
    The A value in the g76 line (or the line above it in the newer machines) is the angle of the included thread if you watch the control the start position of each pass comes closer to Z0.0. That being said it sounds to me like you have one of 3 problems, 1 Your tool is offcenter, most nc machines are just slightly below center, sometimes a shim helps with general tuning its not a big deal, but when you are dealing a small radius tool it will come more into play. 2 It is likely that your set up is not rigid enough Are your jaws bored to the diameter of the part? 3 Do you have a tailstock?
  1. Threading MDF
    By Me2 in forum FAQ of DIY CNC Machine Building
    Last Post: 05-26-2011, 06:08 PM
  2. MDF threading
    By MrWild in forum Commercial CNC Wood Routers
    Last Post: 01-01-2010, 05:17 PM
  3. ID Threading
    By Toddjones in forum G-Code Programing
    Last Post: 05-24-2009, 06:46 PM
  4. CNC Threading
    By metalworker in forum Mini Lathe
    Last Post: 10-31-2004, 07:14 PM
  5. Threading Help Please
    By Donovan in forum MetalWork Discussion
    Last Post: 10-31-2004, 05:22 AM
