588,572 active members*
9,706 visitors online*
Results 1 to 4 of 4
    Aug 2008
    573
    Help: updating 2.2 ->2.3
    I'm trying to update emc2 2.2.8 to 2.3.x on Ubuntu 8.04 Hardy heron
    If I run emc2-install.sh fails - suggesting 'manually run dpkg' scrolling up the terminal windows show a failure at the beginning of the script - sudo unable to resolve host Axis [Axis is the name of the machine]
    I'm very much a linux newbie (and to be honest, I hate its cryptic processes) so please be patient.
    Code:
    bill@Axis:~$ '/home/bill/Desktop/emc2-install.sh'
    sudo: unable to resolve host Axisgpg: requesting key 8F374FEF from hkp server pgpkeys.mit.edu
    gpg: key 8F374FEF: "EMC Archive Signing Key " not changed
    gpg: Total number processed: 1
    gpg:              unchanged: 1
    OK
    Hit http://security.ubuntu.com hardy-security Release.gpg
    Ign http://security.ubuntu.com hardy-security/main Translation-en_GB
    Ign http://security.ubuntu.com hardy-security/restricted Translation-en_GB
    Hit http://gb.archive.ubuntu.com hardy Release.gpg
    Hit http://gb.archive.ubuntu.com hardy/main Translation-en_GB
    Hit http://gb.archive.ubuntu.com hardy/restricted Translation-en_GB
    Ign http://security.ubuntu.com hardy-security/universe Translation-en_GB
    Ign http://security.ubuntu.com hardy-security/multiverse Translation-en_GB
    Hit http://gb.archive.ubuntu.com hardy/universe Translation-en_GB
    Hit http://gb.archive.ubuntu.com hardy/multiverse Translation-en_GB
    Hit http://gb.archive.ubuntu.com hardy-updates Release.gpg
    Ign http://gb.archive.ubuntu.com hardy-updates/main Translation-en_GB
    Ign http://gb.archive.ubuntu.com hardy-updates/restricted Translation-en_GB
    Ign http://gb.archive.ubuntu.com hardy-updates/universe Translation-en_GB
    Ign http://gb.archive.ubuntu.com hardy-updates/multiverse Translation-en_GB
    Hit http://security.ubuntu.com hardy-security/main Packages
    Hit http://security.ubuntu.com hardy-security/restricted Packages
    Hit http://security.ubuntu.com hardy-security/main Sources
    Hit http://security.ubuntu.com hardy-security/restricted Sources
    Hit http://security.ubuntu.com hardy-security/universe Packages
    Hit http://gb.archive.ubuntu.com hardy/main Packages
    Hit http://security.ubuntu.com hardy-security/universe Sources
    Hit http://security.ubuntu.com hardy-security/multiverse Packages
    Hit http://security.ubuntu.com hardy-security/multiverse Sources
    Hit http://gb.archive.ubuntu.com hardy/restricted Packages
    Hit http://gb.archive.ubuntu.com hardy/main Sources
    Hit http://gb.archive.ubuntu.com hardy/restricted Sources
    Hit http://gb.archive.ubuntu.com hardy/universe Packages
    Hit http://gb.archive.ubuntu.com hardy/universe Sources
    Hit http://gb.archive.ubuntu.com hardy/multiverse Packages
    Hit http://gb.archive.ubuntu.com hardy/multiverse Sources
    Hit http://gb.archive.ubuntu.com hardy-updates/main Packages
    Hit http://gb.archive.ubuntu.com hardy-updates/restricted Packages
    Hit http://gb.archive.ubuntu.com hardy-updates/main Sources
    Hit http://gb.archive.ubuntu.com hardy-updates/restricted Sources
    Hit http://gb.archive.ubuntu.com hardy-updates/universe Packages
    Hit http://gb.archive.ubuntu.com hardy-updates/universe Sources
    Hit http://gb.archive.ubuntu.com hardy-updates/multiverse Packages
    Hit http://gb.archive.ubuntu.com hardy-updates/multiverse Sources
    Hit http://www.linuxcnc.org hardy Release.gpg
    Ign http://www.linuxcnc.org hardy/base Translation-en_GB
    Ign http://www.linuxcnc.org hardy/emc2.2 Translation-en_GB
    Ign http://www.linuxcnc.org hardy/base Packages
    Ign http://www.linuxcnc.org hardy/emc2.2 Packages
    Ign http://www.linuxcnc.org hardy/base Sources
    Ign http://www.linuxcnc.org hardy/emc2.2 Sources
    Hit http://www.linuxcnc.org hardy/base Packages
    Hit http://www.linuxcnc.org hardy/emc2.2 Packages
    Hit http://www.linuxcnc.org hardy/base Sources
    Hit http://www.linuxcnc.org hardy/emc2.2 Sources
    E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
    bill@Axis:~$
    Bill
    Jul 2003
    1760
    Aug 2008
    573
    When I run System/Administration/Synaptic Package Manager I get the dpkg error (which cannot be copied and pasted !!!!) saying something like dpkg has been interrupted run dpkg --configure -a manually to correct problem.
    When I try to run this in a terminal I get: you need superuser privileges to run....
    I'm sure the package manager was working recently, since I added linux.org to the list. There was a bunch of ubuntu updates applied just prior to my attempts to upgrade (all except a wine update installed OK) could this be the problem?
    Bill
    Aug 2008
    573
    Success
    Managed to run dpkg (remembered what sudo command was :0). There was an update pending/unfinished. Once this had time to do whatever it was doing, I modified the package info from 2.2 to 2.3 and ran the updater.
    So now i have 2.3.1
    Thanks for your help Sam.
    Bill
  1. updating biesse to new program
    By firebird in forum Commercial CNC Wood Routers
    Last Post: 12-05-2009, 07:44 PM
  2. Updating An Old Drawing
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 06-12-2007, 05:27 PM
  3. Fanuc code needs updating.
    By Roberts in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-22-2006, 02:45 AM
  4. Precaution when updating OnecncXP
    By HuFlungDung in forum OneCNC
    Last Post: 06-03-2003, 04:23 PM
