603,924 active members*
4,166 visitors online*
Results 1 to 6 of 6
    Aug 2004
    309
    help with viewing nc file
    I hope this is in the correct forum. I bought some stamping dies and received a disk with nc files for the two pieces I need to produce the parts needed for the dies. I am unsure if the files are for a water jet laser etc as they are in a formatt my machine cant interp. Is there someone here that could take a look at the files and just generate a couple of dxf files of the two parts so I can generate usable gcodes for my machine?
    I changed the ext fron .nc to .txt to attach
    Thanks for any help
    Attached Files Attached Files
    Aug 2003
    20
    Hi!
    Here are converted files in DXF...
    I made them with my little utility (Link). You should give it a try!
    Hope this helps.
    Apr 2005
    3634
    Actually it should easy for you to get what you need from the above .txt files that you posted.
    Just open the .txt file & delete the code thats not g-code.
    Then open in www.ncplot.com , & edit the code by hand.
    Example below:
    Jun 2003
    3312
    I'll second that, NCPlot is a great tool.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Aug 2003
    20
    Yes, NC-plot is a great tool for preview/backplot! But free version is really a basic release and lacks a lot of features: DXF export, in particular, which is needed for the job discussed here. Beyond that, even with last V2.02 I tried, DXF export didn't look really good (entities missing), that's why I developped simple software (but not that basic...) I told about a few posts above. I offer it free and it definately deserves a try...
    ...As resequence software I post a few months ago, does: It's much more complete than all softwares I found until now. I think it should be really useful for people who are mainly programming with hand and/or tweaking programs after CAM post-processing (Tiger/Fanuc/Num controllers).
    Aug 2004
    309
    thanks guys it was the ; at the end of each line my controller wasnt comfortable with
  1. Need help viewing with a pm4 file
    By pixburghenat in forum Uncategorised CAM Discussion
    Last Post: 12-01-2010, 07:01 AM
  2. Video Viewing Problems
    By bigz1 in forum Mach Software (ArtSoft software)
    Last Post: 05-21-2007, 08:05 AM
  3. Viewing and printing dfx with A9cad
    By mlaws1172 in forum Waterjet General Topics
    Last Post: 12-07-2006, 06:59 PM
  4. viewing .dxf files Linux
    By Breaker in forum OpenSource Software
    Last Post: 10-01-2006, 11:14 PM
