603,850 active members*
5,694 visitors online*
Page 2 of 2 12
Results 21 to 37 of 37
  1. #21
    Apr 2006
    10
    The dino`s are cool.
    I`m a programmer on a OMADA LC2415 lasercut machine and i also cut myself. It can cut 12 mm thick steel and 6 mm stainless steel.
    This week i`m going to cut two raptors from 4 mm thick steel.
    Now i want that Eagle :-)
    Some one can convert fgc to dxf?
  2. #22
    Apr 2003
    159
    Quote Originally Posted by Lightbeing
    Hi The fgc file is the Gcode for the eagle, but I'll attach the dxf file sorry about that. Jim
    Attached Files Attached Files
  3. #23
    Apr 2006
    10
    Quote Originally Posted by jimini
    Thanks man.
    Going to cut it also this week from steel. I`ll put the eagle on the roof of my barn :-)
    Super.
  4. #24
    Apr 2006
    10
    And this is the result. The date on the camera is not good, must be 3-5-2006 :-) I also have the feathers on the other side.
  5. #25
    May 2006
    40
    Thanks to all that have shared. :cheers: These are great.
    How are you holding down the wood? I've used 2 way tape before, but have not had good luck with small, thin objects. They tend to split or pop off. (maybe I should have turned down the feed rate)
  6. #26
    Apr 2003
    159
    Great adaptation lightbeing.
    One small item... It appears you have the wings on backwards, the feather tips should point to the rear.
    Whoops, on rereading your message I see you caught that.Jim
  7. #27
    Apr 2006
    10
    Yep, i`m going top make another one next week :-)
  8. #28
    Nov 2005
    12
    A Lot of examples ( not only animals or sauri ) can be found here:
    http://5128.rapidforum.com/topic=111980147605
    Regards,
    Hugo
  9. #29
    Jul 2003
    276
    my German is rreally rusty....
  10. #30
    Apr 2006
    10
    Somewhone has a dxf of a bird like this?
    http://www.laubsaegearbeiten-mueller.../produkte2.htm
  11. #31
    Apr 2006
    10
    Made one myself from a picture with Solid Edge.
    DXF
    http://home.planet.nl/~lightbeing/vogel.dxf
  12. #32
    Apr 2006
    10
    I also have a tiger for lasercut. On the foot you have bend the flip 95 degrees.
    DXF
    http://home.planet.nl/~lightbeing/tijger.dxf
    And a beautifull head
    http://home.planet.nl/~lightbeing/head.dxf
  13. #33
    Jul 2003
    276
    Not to sound like a total newbie (HAHAHA which I am) but that head is HUGE
    how can I scale it down?
    MAJOR DOH! I opened as inches and it is metric... Didi I mention I was a newbie at this?
  14. #34
    Apr 2006
    10
    Quote Originally Posted by randyf1965
    Autocad or Solid Edge for example.
    Wait, i do it
  15. #35
    Apr 2006
    10
    Head in small format for lasercut.
    DXF
    A bull
    DXF
    http://home.planet.nl/~lightbeing/stier.dxf
    Another cool one.
    DXF
    http://home.planet.nl/~lightbeing/vampier.dxf
    To make things like this you must save some pictures like i did
    After that you import the picture in Solid Edge in sheet metal. Draw it over in lines by hand and convert the line to a tab and cut the rest out. After that you can save the dxf.
    More cool stuf from here http://www.emax24.de/caseking/laser_...rgitter/1.html
  16. #36
    Apr 2004
    162
    HELP with this file
    *EDIT* Never mind.. I finally found a photo of this actual dinosaur plan assembled, and using it, I was able to quickly discover why I was having difficulties.. got it all assembled, except i have *NO* idea where the 2 pievces go that look like an arch with a slot in the top, and one end pointed... seems like it looks right without these pieces, and there are no unused slots available, so I don't know why these pieces are in the plans.. Sure I am doing something wrong..
    Going to try attaching a pic of the 2 dinos I have cut out ..
    EDDIE
    *Original MSG* I cut all the parts in this file, but there is only a single page of parts, and it appears some are missing.. is this file complete?
    Eddie
    Quote Originally Posted by JulioHB View Post
    Hello!!!
    here is the Velociraptor.. he is optimized to laser cut...
    hey people let upload more files ....
    t+
  17. #37
    Apr 2005
    11
    Hello people,
    than you for the files,
    I will be uploading more files soon
    Thank You!
    t+
Page 2 of 2 12
  1. york and lancaster couny i can not find anyone
    By harolda in forum Mentors & Apprentice Locator
    Last Post: 08-21-2006, 04:37 PM
  2. The most useful software that I cant find!
    By berin in forum Uncategorised CAM Discussion
    Last Post: 12-10-2004, 06:38 PM
  3. Where to find surplus Tslots or 80/20
    By samualt in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 11-05-2004, 08:04 PM
  4. I hate losing Links, trying to find ones for Thomson Bearings
    By CNC Brute in forum DIY CNC Router Table Machines
    Last Post: 01-23-2004, 07:16 PM
  5. Find and Replace
    By HuFlungDung in forum OneCNC
    Last Post: 05-13-2003, 12:05 AM
