567,245 active members*
3,622 visitors online*
IndustryArena Forum > CAM Software > EnRoute > Help with using multicam vision and enroute
Results 1 to 4 of 4
    Jun 2010
    I have been using enroute on multicam routers for over 12 years. I recently changed jobs and the software they were using was EZG code creator. I hate it and was able to get enroute4 from a friend who switched to a different software. Anyway, I have it up and running but I am trying to set it up to use the multicam vision when we print on acrylic and I cannot figure out how to set the tool up. I read that I need to make it tool 99, but I do not know how to create to tool in the tool library. Any help would be appreciated.
    Aug 2008
    63
    Re: Help with using multicam vision and enroute
    what you need to do is very simple
    set a new tool
    with 1/4 "diameter at which
    you're going to name a camera
    and thou shalt put that tool in position # 99
    Jan 2023
    I am tasked with getting our Multicam camera functionality up & running again after we lost our operator. I was able to get the camera calibrated & the camera offsets set. When I attempt to program a simple test cut... The Multicam will read all regmarks, then it pauses right before it is supposed to do the tool change for the final Cut. The G-Code looks OK, from what I can tell. And there are no "extra point or lines" left over, that could cause an issue. I am fresh out of ideas.... Our VISION tool is setup as Tool 99 in our enroute tool library, but I do not see a place to mirror that in the Multicam / Job Console. Any help would be much appreciated.
    *Registered User*
    Jul 2014
    215
    Quote Originally Posted by kvallery View Post
    When I was last moving Enroute to a different computer and had to set it up again I noticed that there were several post processors for other multiCAM products. you might need to select another post processor when you are using the optical vision head for doing that. Also, if you are the original purchaser of the machine you have free technical support.
  1. Multicam 6610 communication issue with EnRoute 3.3
    By jhansLV in forum Multicam Machines
    Last Post: 01-21-2012, 12:20 AM
  2. EnRoute 3.3 and Multicam 6610
    By jhansLV in forum EnRoute
    Last Post: 01-21-2012, 12:02 AM
  3. VISION 810 or 1212
    By Ideas L in forum Engraving Machines
    Last Post: 04-19-2011, 09:26 PM
  4. EZ Vision
    By TravisW in forum Bridgeport / Hardinge Mills
    Last Post: 03-04-2011, 03:33 PM
