603,960 active members*
2,462 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Help with VFD for manual lathe.
    Jun 2019
    4
    Hello all
    I have an old Bradford lathe that I'm trying to power up with a Vivor 4kw vfd. I'm not sure of the settings to set in the vfd. Any help is greatly appreciated.
    Jun 2019
    4
    Re: Help with VFD for manual lathe.
    Well disregard, got it figured out!
    Jan 2005
    15362
    Quote Originally Posted by mmarmino View Post
    Most Parameters would be at Default for that motor, does it have a clutch, or is it direct drive.
    Mactec54
  1. Replies: 0
    Last Post: 03-25-2021, 07:32 PM
  2. Huanyang SL-240EE Manual (SL Series Manual for Vector VFD)
    By Cogolith in forum Phase Converters
    Last Post: 05-24-2016, 04:19 AM
  3. Clausing Colchester manual lathe conversion to CNC (keep manual also)
    By 86turbodsl in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 01:50 PM
  4. manual lathe convert cnc/manual lathe
    By kakayo in forum Vertical Mill, Lathe Project Log
    Last Post: 02-21-2010, 08:13 PM
