Similar fix.
Excellent work David!
I am working on a similar fix for transferring the PWM spindle speed control signal and direction bit direct to the motor control board bypassing all the rubbish and the micro on an intermediate board.
Just have to finish tracing out all of the circuits before I commit it to the soldering iron. I will opto-isolate if required.
Target is to get SOLID TAPPPING under Mach3 working. Tacho signals from tacho generator chip will do perfectly, because of cog belt drive.
Probably will use a PIC to perfect this without too many parts. Depends on belt ratio issues.
Due to differences the early and late model motor boards need a different approach. I will do the early, then the later version. (as time permits!)
Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
