587,362 active members*
3,616 visitors online*
Thread: Hercus lathe
Results 1 to 4 of 4
    Aug 2004
    68
    Hercus lathe
    I have searched and found a few older posts around the Hercus lathes. I have aquired a compulathe, 1986 production model with coolant, 8 position tool changer, pneumatic chuck. Seems to be complete. Needs the little battery replaced I'm sure before I can go on. Any one ever get anywhere with theirs?
    Nov 2006
    925
    I see it`s got an Anca control.Macona on the HSM forum has a Hercus that he ripped the control off and is setting up to run with mach I think.He updates the thread quite often.
    Mark.
    Oct 2009
    45
    I was just serching for info to retrofit my Hercus V300 mill which had all it's electronics & servo's removed by the previous owner.... and I noticed your post.
    It looks like you have the "Industrial" version of the lathe, I have the "Educational" version with the same options as yours, but without the coolant. When I got it 12 years ago it was non-functional, but I was able to revive it to fully functioning ! Unfortunatly over the years I think oil has seeped onto the main control board in the cabinet underneath and is now causing the servos to malfunction. Your control is in a better location at the back away from oil drips.
    I was lucky though... the trade school that sold mine still had some replacement parts, manuals, and lots of advise...
    The machine itself is very well built; high quality workmanship and well thought out design (nice integrated way-covers)... but the electronics broke down a lot, that it why they got rid of them.
    If you happen to have any parts available let me know. I may be able to help with yours, but it has been a long time ago since I was inside the machine... but there is a company that is servicing the controls - I have not contacted them so I cannot vouch for them... http://www.ultralogic.com.au/Default.htm
    Aug 2004
    68
    I hae been in touch with Ultra Logic. They will service, but I have to send the board to Australia to have it happen. There is another company over there that is working on a retro fit for the Hercus lathe, but it is out of my budget.
    I was hoping for some one to tell me that this would be easy =8^}. I would like to know why I can't take some one's break out board, put encoders on my servos, and make it work. Now, I am very electronically challenged, but how different is that than building a home done cnc?
  1. Hercus PC200 Retrofit
    By isjohn in forum Servo Motors / Drives
    Last Post: 12-03-2015, 01:49 AM
  2. Resurrection of a Hercus v300 Compumill
    By UWA_FYP_CNC in forum Benchtop Machines
    Last Post: 07-03-2012, 06:21 AM
  3. Hercus Computurn
    By Doug Baker in forum Australia, New Zealand Club House
    Last Post: 04-16-2009, 04:45 AM
  4. Hercus V300 COMPUMILL DNC
    By Jonathon in forum DNC Problems and Solutions
    Last Post: 11-04-2008, 11:23 AM
