587,515 active members*
3,046 visitors online*
    Apr 2009
    6
    here is my driver test,is this good
    can enybody help me about this .is this ok or not driver test.
    that is test in one monement and after 5-10 seconds.
    is this my general configuration ok checked?
    best regards
    Attached Thumbnails Attached Thumbnails dia.bmp   driver test.bmp   driver testt.bmp   gc.bmp
    Jun 2005
    138
    Just like the internal diagnostics shows on your screen during that test, your parallel port performance is excellent.
    In your General Configuration, everything seems fine, also.
    Are you trying to diagnose a problem, or just asking others to double-check your setup?
    Apr 2009
    6
    hello
    i was thinking that i had a problem with slow pulse.
    i am glad to hear that you think that is all ok.
    i just wonna hear your opinnion about my situation driver test.
    thank you very much.
    Osman
  1. Running driver test, nothing happens
    By Tony611 in forum Mach Software (ArtSoft software)
    Last Post: 01-25-2009, 08:22 PM
  2. Driver test question
    By woodr004 in forum Machines running Mach Software
    Last Post: 01-12-2009, 05:12 PM
  3. Driver test problem...
    By jaru-eri in forum Mach Software (ArtSoft software)
    Last Post: 02-20-2008, 12:38 AM
  4. Test steppers with driver only?
    By monte55 in forum Xylotex
    Last Post: 10-20-2006, 12:55 AM
  5. Mach Driver test => Max 23,800Hz
    By haysys in forum Mach Software (ArtSoft software)
    Last Post: 12-18-2005, 08:12 PM
