587,405 active members*
3,133 visitors online*
    Apr 2018
    8
    Herluce EP4030
    Good afternoon:
    I have a Herluce EP4030 model year 2000 milling machine,
    it is the same as the Isel ICV 4030.
    It uses the nascad 2000 software.
    Would it be possible to use other software such as mach3 or similar?
    The problem is that it is executed by msdos in a windows 98 and I would like to put it in a more modern computer.
    Attached screenshots of the program
    this is the home screen
    here you have to choose ISEL-EP.EXE
    This screen is for moving Y X and Z axes
    And this is the program files.
    The executable is NC.com
    The license is in a parallel port, and the machine is connected to the PC through a serial port cable.
    Could you use another program easier and in a more modern computer?
    Regards
    Apr 2018
    8
    Re: Herluce EP4030
    up!!
    Apr 2018
    8
    Re: Herluce EP4030
    up!!
