603,981 active members*
2,179 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > hesitation after m code
Results 1 to 6 of 6
    Apr 2006
    43
    1993 vmc15, after any m code entered, e.g. m6t1, the machine sits and waits for a least 4-6 seconds before it moves. has anyone had this problem, and what is a possible fix? Thanks.
    Aug 2005
    4
    I'm not sure of what type of machine you have or the controls, but maybe you should try to pre position the tool.
    Jan 2004
    3154
    Just to clarify After ANY M code?
    M6 M3 M8 M19?
    Sounds like controller or wiring problem.
    If it is only on 1 M code I would think it is the relay.
    Check to see if your input control voltage is correct on the feed side of your relays, could have a bad low voltage PS
    www.integratedmechanical.ca
    Apr 2006
    43
    Its a Fadal VMC 15 with a standard control 88 (serial # 9305356)(Built in 1993). The system software has been updated to 102.1, and has memory upgraded to 422k total memory. Its happens when using any m code( machine hesitates(there is a noticable delay). And it happens every time, all the time.
    Mar 2003
    900
    Andy--
    When the upgrade was done, was the zero memory procedure done? Also, do you know what software version was in the machine before the upgrade?
    Neal
    Apr 2005
    1194
    Do you have rigid tapping and do you have any issues with it breaking taps? Does the spindle act erratic at the high range of either low or high gear? If so sounds like your encoder is dirty.
