603,783 active members*
2,569 visitors online*
Results 1 to 5 of 5
    Oct 2009
    27
    Hex Bar Stock turned and drilled/tapped
    I need qty 100 of these items. I would like quotes to offer material options of mild steel and 7075 Aluminum. Based on pricing, I will select one of the following two designs and material. The job is time sensitive, turn around time needs to be less than 2 weeks. The first part in question is 3/4 hex stock, approx 2.33" in length, turned to a 60 degree taper on one end and drilled and tapped for a 12x1.5mm through hole. The second is based on 1 inch round stock with the same taper and through hole. The hex is machined in this version. Preference will be given to Los Angeles area shops. I will not consider overseas suppliers.
    Thanks You.
    Attached Files Attached Files
    Nov 2008
    61
    PM sent.
    Sep 2009
    313
    PM SENT...
    Sep 2010
    Can you please send the prints to [email protected] so we can work out a quote. We are located in Cerritos, CA. Thank you.
    Sep 2009
    313
    Have you awarded this job yet? We sent you a quote about 2 weeks ago...
  1. RFQ - Turned Steel w/ Drilled & Tapped Set Screws (Cancelled)
    By AuroraDrvr in forum Employment Opportunity
    Last Post: 04-14-2009, 07:12 AM
  2. Drilled & Tapped Precision Shafting
    By justCNCit in forum Mechanical Calculations/Engineering Design
    Last Post: 12-24-2008, 12:56 AM
  3. Replies: 9
    Last Post: 09-12-2006, 01:26 PM
  4. RFQ - small mild steel turned and drilled parts
    By mcmmach in forum Employment Opportunity
    Last Post: 07-29-2005, 03:37 AM
  5. Are sherlines drilled and tapped??
    By BriteHarry in forum Mini Lathe
    Last Post: 10-15-2004, 01:36 AM
