603,316 active members*
2,227 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > HF 4" x 5" micro lathe for $72.87 ???
Page 2 of 9 1234
Results 21 to 40 of 173
  1. #21
    Dec 2009
    45
    The tool post is 7/16", spindle 13/32" (10mm), chuck 1 3/4" according to the pdf manual.
    I received the shipped via FedEx email from Harbor Freight this morning. :banana:
  2. #22
    Feb 2010
    LMS sells a 2" chuck to increase it's capacity. "This chuck has a M14x1 threaded through hole (approximately 13 mm) . It holds work up to 1.30" (33 mm) in diameter." I'll bet a 3" fits as well, but you might not be able to open the jaws all the way. As far as practical capacity, we shall know soon enough!
  3. #23
    Nov 2007
    617
    A lot of the practical capacity will probably relate to material type being machined. 2" may be ok for aluminum, brass, or other soft material, but steel I don't know. Certainly you could turn 2" steel if you had the chuck, but I wouldn't want to run production on it.
  4. #24
    Mar 2010
    I'm interested it in for machining small wood parts.
    Not sure I get what all the eye rolling is about.
  5. #25
    Sep 2008
    111
    ordered mine today. does anyone know what taper the tail stock is?
  6. #26
    Feb 2010
    Quote Originally Posted by cad01 View Post
    I believe 10 mm straight shank based on the fact that LMS offers a live center to fit. Many of their parts are for a C0/Unimat 3 & 4, causing me to believe hte head/tail stocks are the same. The steady rest is also fitting the Unimat4. Could it be a Unimat 4 clone of sorts?
    http://www.lathes.co.uk/emco/page3.html
  7. #27
    Nov 2007
    981
    Quote Originally Posted by stephenrc View Post
    Could you please share the link to the PDF manual?
    Thanks so much-
    Dave
    EDIT: I believe I found it: http://www.siegind.com/product.php?id=21
    Dave->..
  8. #28
    Dec 2009
    45
    The above link is a page describing the lathe and accessories.
    The manual link is right below the add to basket link for the HF 95012:
    http://www.harborfreight.com/cpi/cta...m&ItemID=95012
  9. #29
    Nov 2007
    981
    lol, can't believe I missed that!!
    Dave->..
  10. #30
    Nov 2007
    617
    Quote Originally Posted by n_maher View Post
    Should be absolutely great for wood. The eyerolling is mostly because this lathe is not taken seriously, and is considered a "toy" by many. Be that as it may, it is still obviously useful and valuable in the proper context, and it is far from a toy, as it's built like any other lathe, just scaled down and without the benefit of power feed. I still say this would make a pretty cool CNC project, and you can bet I'll be evaluating it for that! At $82 shipped, it's a great value for anyone. At $300, people were not beating a path to HF's door to buy it. I think if they had priced it under $200 they may have been more on-target.
  11. #31
    Feb 2010
    Back on the tapers, parts available from LMS and this about unimat 3:
    "The headstock spindle was bored through a generous 0.4" (10.2 mm) and carried a nose thread of M14 (similar to DIN 800)"
    and this
    "The tailstock barrel had a travel of 0.9" (23 mm), but did not have a taper - instead it carried a replica of the headstock spindle thread."
    and from the manual:
    Electrical Requirements 110 VAC / 60 Hz / 150 Watts / 1.4 No Load Amps / 0.6 Start Up Amps
    1/5 HP Motor
    Fuse Type: F2AL250V
    Power Cord Type: 18AWG x 3C / 4’-7” Long
    Power Plug Type: 3-Prong, Grounded
    Variable Speed Capacity 0 to 3800 RPM
    Chuck Type 3-Jaw Self-Centering
    Chuck Capacity 1-3/4”
    Tool Post Capacity 7/16”
    Hole Through Spindle 13/32” (10mm)
    Swing Over Bed 4”
    Distance Between Centers 5”
    Cross Slide Scale 0.002” Per Each Mark
    Longitude Feed Scale 0 to 2” Per Each Mark
    Tail Stock Quill Travel 1”
    Tail Stock Quill Scale 0.002” Per Each Mark
    Bed Dimensions 14” Long x 3-5/16” Wide x 5” High
    Overall Dimensions 17.35” x 10.63” x 8.27”
    Additional Features Lockable Tool Post/Lockable Tail Stock/Hardened Ways
    Net Weight 30.80 Lb.
    I summize:
    Head and tail have M14x1 threaded mounting on the outside diameter. the hold through the spinal is 10 MM and the tailstock is that same, possibly with some means to secure what would normally be the tapered end of a live center (roller center by the old book).
  12. #32
    Nov 2007
    617
    Thin cross-section of the spindle nose.... 10mm thru hole, 14mm od = 2mm cross-section, -1mm thread depth = 1mm (give or take) of spindle nose cross-section.
    Should be plenty strong for it's intended use, but I wouldn't beat on the chuck with a hammer!
  13. #33
    Jul 2003
    49
    Being that I desperately need something bigger and not smaller, and don't really have $100 to just blow.
    When do I feel such a need to order one? I think it would look good setting on the coffee table.
  14. #34
    Feb 2010
    It probably won't be there for long, 374. Better go lift a wallet or play some poker and get $100
    Quote Originally Posted by blades View Post
    Isn't one of the advertisers here selling a CNC version of this lathe for like $1700? Seems to me I recall clicking on a link one time. It was a very clean-looking conversion.
    Edit: www.novakon.net was the seller, but they don't appear to have it on thier site anymore. Just higher-end stuff.
    Interesting, blades, Sieg has a similar pic, with the belt gaurds for the driving of x and z:
    http://www.siegind.com/product.php?id=38
    So, I guess a CNC'd version is "factory and available... somewhere. Perhaps someone will find a way to order the factory parts. Looks like the lead screw is driven by a shaft under it going back to the main motor.
  15. #35
    Nov 2007
    617
    I also ran across the Sieg pic last night when I was doing some poking around. Impressive they took a closeup shot of it with rust on the ways.
    They did do a very impressive job on the belt guards, looks really professional. I'm not terribly fond of conversions where the motors are sticking straight out from the leadscrews. This thing must use one heck of a tiny Y axis motor! For such a small conversion, it's an extremely professional looking conversion.
    clytle374, the price is very motivating to order one. When I saw it for that price, I didn't even pause before ordering it.
    BTW: got my shipping confirmation email today!
  16. #36
    Feb 2010
    Wow, fast response!
    Quote Originally Posted by SIEG Industrial Group
    Hi Jon,
    Welcome to visit our workshops during your trip to China.
    Regards,
    They sent the parts list and drawing for their CNC version.
    Attached Files Attached Files
  17. #37
    Feb 2010
    HORROR HORROR! Mines back ordered, expected in the next 20 biz days
  18. #38
    Nov 2007
    617
    Doh!!!! Hopefully it will show up though. If HF is discontinuing it, I'm surprised they would have it back ordered.
    BTW: you ROCK for getting those PDF files!!!!
  19. #39
    Aug 2008
    247
    Called this morning (Chicago). Sorry, discontinued. None in the warehouse. Can't sell something we don't stock. Anything else I can help you with?
    ~John
  20. #40
    Nov 2007
    617
    If they had sold it for a reasonable price to begin with, it wouldn't have been such a dud and they wouldn't have had to discontinue it.
    knudsen, I sure hope you get yours!! I think they sold the heck out of these after dropping the price that far.
Page 2 of 9 1234
  1. Replies: 268
    Last Post: 06-03-2012, 11:33 PM
  2. Replies: 15
    Last Post: 05-05-2011, 11:59 PM
  3. The "Parts Bin Micro Lathe"
    By Jason3 in forum Vertical Mill, Lathe Project Log
    Last Post: 03-30-2010, 12:57 AM
  4. WTK: Trico "Micro Drop"
    By Swede in forum MetalWork Discussion
    Last Post: 05-19-2009, 11:10 PM
  5. Low cost "PIC = Micro-controller?"
    By Aan in forum CNC Machine Related Electronics
    Last Post: 04-24-2006, 06:46 PM
