587,890 active members*
4,270 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > hicell ca 23 24volt power alarm fixed now its one more proplem need help
Results 1 to 4 of 4
    hi again
    my chuck clamp doesent work cant close and open it
    and the same with the turret tools cant clamp it or unclamp
    the hydraulic oil pumps works.
    does anyone knowes whats can be wrong
    machine is hicell ca23
    regards Hans
    Dec 2009
    546
    Re: hicell ca 23 24volt power alarm fixed now its one more proplem need help
    Hans,
    does this Hicell have the Seicos III controller? Best place to start is to see if the signals from the button and foot-switch are making it to the control. Let me know the control and I can tell you where to look
    John
    Hi John
    Its seicos lll
    Regards Hans
    Dec 2009
    546
    Hans,
    if the machine is in standby, check out the solenoids for the clamp/unclamp for the chuck and tool block. They often get fried and no longer respond. You should see a light corresponding to the current state of the chuck and tool (both should be clamped at this point, I assume)
  1. have proplem to run my spindle
    By andreastsappas in forum Servo Motors / Drives
    Last Post: 09-29-2013, 04:41 AM
  2. Replies: 6
    Last Post: 03-13-2013, 03:32 PM
  3. Hitachi Seiki/Hicell/Seicos LIII/ Alarm 950
    By Karsue in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-04-2012, 10:13 AM
  4. 24volt 10amp transformer
    By stirlingnut in forum CNC Machine Related Electronics
    Last Post: 03-20-2006, 04:04 PM
  5. 24volt DC motor control
    By TinkerDJ in forum CNC Machine Related Electronics
    Last Post: 01-12-2005, 04:42 PM
