588,212 active members*
4,316 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > High Quality and Cheap CNC WOOD ROUTER
    Jun 2012
    1.Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
    2.Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
    3.Three axises are precision ball screw vice transmission, reasonable structure, stable performance, good weight bearing ability.
    4.This machine is mini machine, low price, high performance, especially suitable for home and small enterprises,institutions* to do processing .
    5.Users can* assemble electric spindle and driving control system according to their own needs.
    Specification:
    X Y axis working area 300 x 200mm
    Z axis working area <60mm
    Table size 370mm x 440mm
    Max. speed 0 - 4,000mm/min
    Max. working speed 0 - 4,000mm/min
    Working delicacy 0.015mm
    Reposition accuracy 0.05mm
    Max. feeding height 60mm
    Command G code *.u00* *.mmg* *.plt *.nc
    Software Type3, Artcut, Artcam, Ncstudio software
    Max. power consumption 1.2KW
    Spindle 0.8 kW variable speed, water cooled motor
    Spindle speed 24,000rpm
    Work type stepper
    Working voltage AC 220V, 50/60Hz
    Memory 32M
    Manner of receiving data USB OR PCI*
    Running circumstance temperature 0 - 45℃
    Relative humidity 30% - 75%
    Weight 57kg
    Jun 2012
    cnc router samples
  1. Can anyone recomend a high quality china cnc router import?
    By lotus329 in forum Commercial CNC Wood Routers
    Last Post: 11-10-2017, 02:16 AM
  2. anybody need CNC Router with high quality and lowest price?
    By wklaser in forum News Announcements
    Last Post: 08-27-2008, 11:29 AM
  3. High Quality Cnc Router
    By aghobby in forum News Announcements
    Last Post: 08-27-2008, 11:15 AM
  4. High-quality CNC router
    By ice in forum News Announcements
    Last Post: 08-27-2008, 10:54 AM
  5. Cheap with high quality --- Artisman CNC router manufacturer
    By DanWei in forum News Announcements
    Last Post: 08-02-2007, 03:47 AM
