603,832 active members*
4,957 visitors online*
    Jan 2004
    539
    High Speed File Server
    Anyone here used this or a product like this? The dealer thought that you could edit programs through the control when using this..but wasn't sure with my control. It was too late to talk to them today so tomorrow I will find out the details. $1850. If it works I am going to jump on it. I have to find out some way to make this thing actually cut chips for a change. :bs:
    Gary
    http://www.memex.ca/index.php?option...&Itemid=200085
    Mar 2006
    167
    Is that price for the whole configuration, or just the Ax2200HS-Fs unit? Otherwise, it is going to be an expensive option. It pretty much mimics the Fanuc data server in functionality, except transfer to the machine which is RS232 with this option, and Ethernet with data server.
    Nov 2006
    418
    You may take a look at this:
    http://www.calmotion.com/lancnc.html
    It looks to have much the same functionality, but at about 1/4 the price. The high speed transfer may be beyond what you can put to use, depending on your machine and control.
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. High speed machining
    By cncwhiz in forum Fanuc
    Last Post: 12-05-2009, 01:07 AM
  3. High Precision, High Speed Bearings
    By mikeyg in forum News Announcements
    Last Post: 09-08-2009, 01:06 AM
  4. High Speed CNC Routers
    By unitech in forum Videos
    Last Post: 07-27-2009, 10:22 AM
  5. High speed air spindle
    By pebbert in forum MetalWork Discussion
    Last Post: 11-08-2008, 09:25 PM
