I am looking for anyone who might have a High Speed Milling spreadsheet. That will give me speed, feeds, depth of cut and anything else that will come in handy for programming.
I am using Mastercam.
MachineSMM
I tried to download some info but it hurts when i stick the wires
in my ear.
But seriously let me see what i have at work and i'll get back
to you tommorrow eve. PEACE
I will get you a spreadsheet tomarrow. I is feed and speeds for some materials. You can e-mail me every once in a while and I will send you an updated one. I up date it as I learn them.
I have a disk that contains info on mastercam high speed I will get it out and see about uploading some of the info to the FTP.
This disk came from Mastercam office.
Cadcam
Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
I will take any information that I can get my hands on.
MachineSMM
I will get it up to the FTp this weekend and post here when it there.
Cadcam
MachineSMM
Sorry for making you wait. I uploaded the files Jimmy sent
me to the ftp site, unspec. uploads folder.
If you need any specific info PM or e-mail me.
PEACE
MachineSMM
This forum rocks and Hardmill your site rocks I am so glad I found all this. I need more.
Glad you like : Tell a friend or two :banana:Originally posted by grantmi1
Friends? What friends. I am a computer hermit.. Um ya I don't have many friends that machine. You can all be my friends. I am a young whipper snapper that is continuing this high speed revolution
Thanks for the kind words Grant.
And welcome to the forum. Very glad to have you here.
PEACE
Try this After down load look at the Calculator.
http://www.betatechnical.com/autonc.htm
Some of Our Customers are using Siemens 810D Control for Die & Mould machining. They use softwares like TEBIS, Surfcam etc.
I want to know, what commands should be written on the Top of the Part Program, to run highspeed milling.
Also how can we activate handling of acceleration & decceleration in Siemens 810D?
smabhyan
Hi. The only true way to document feeds and speeds for machining, expecially with 5 axis machining, HSM and High Veloicity machining is to be able to obtain dynamic information to obtain correct speeds and feeds, depth of cut, etc. A general spreadsheet only contains general speeds and feeds which should be available thru most tool supply companies like Ingersol, Sandvik, etc. I am sure you can get a CD from them of data. (This information provided from them - does not include dynamics for calculations) If you want to pump up the volume and be more precise in determining your shops needs for feeds and speeds, depth of cut, material, power, etc you might look into CHiPS. It is a custom database, uses dynamics and is the cutting edge. See mfg-labs.com. There will be article out in Mold Making Technology in September 2004 called "Chatter Myths" that will tell of some dynamic information required for feeds and speeds, it might give you some insight for things to come.
Hi! I know this has been a very old topic but will someone kindly share with me your excel spreadsheet for HSM cutting conditions? Thanks in advance! I am a newbie by the way
For a free trial of The Machinist Black Book email DaVicki-llc@outlook,com and put trial in the subject.
Speed and Feed calculator for over 3000 materials and handy references for the machinist and programmer.
