Well, I might as well jump in here ![Smile](images/smilies/smile.png)
I'm just finishing up my mill, it's overall dim's are 20 x 10 x ~5 feet.
Reading the first bit of your thread several things come to mind.
1) If your serious about producing a high end router, the money you've set out is about 10% of what it will really take to do the job. Your linear rails are going to cost you ~ $3000, that is unless you plan to buy little pc's off ebay, in that case.. it'll be a real struggle to get any precision.
I realize you have lots of mat'l already in hand, but I question if its the correct mat'l. Someone mentioned larger tubing, I would give some SERIOUS thought to that point.
2) It would appear that you've taken a simple fixed table design and extrapolated it for size. I'd re-look at that design, having a center drive for that large of a gantry is just not going to work, it will be one racking headache after another. Dual drives from either end of the gantry is the ONLY way to make that work decently.
3) Check out the 'Polymer Concrete' thread, there is some very interesting dicussion on how to build larger structures which are flat and will give planer rail mount surfaces. If/when I build my next machine there will be some changes on how I approach my build/design, based on this info.
4) The less welding you do, the better. If you came make use of large structural sections instead of little pc's [ like 1" dia pipe] do so, cutting and fitting that 1" pipe is going to drive you crazy and as was mentioned.. you'll end up w/ a nice large curvy pc of art, not a router table. If you've ever bellmouthed and fit pipe, realize that doing it for a router table is going to be that much worse. [just laying out the cuts is a huge PAIN]
5) Buy the tools you need, renting the plasma is fine, but get decent machinist tools for layout and what not. Precision level/type tools are a must.
[again budget several thousand dollars]
I was where your currently at about 1.5 yrs ago and have learned much since then [mainly the hard way
]. I was a little more conservative on my cost estimates and came out w/ ~$10k. Later I changed up to linear rails and really started looking over how well my idea would work and realized that alot more had to be spent to get a decent machine. So far I'm WELL over three times my initial estimate. Can it be done cheaper, sure but not a whole lot. If you want 'high end' then there is a cost that goes along w/ it.
Keep at it, and realize that there is ALOT of help for offer on the forum [ and no I'm not talking about my presence here
] there's lots of great people on here!
Ok, I'll get off my soap box now ![Big Grin](images/smilies/biggrin.png)
Jerry
JerryFlyGuy
The more I know... the more I realize I don't
