603,853 active members*
5,019 visitors online*
Results 1 to 4 of 4
    Sep 2007
    138
    Hinge forming tool
    Hi..looking for a tool that can form long hinges tool..
    searched the net for some form tools but coudnt..
    anyone can help?
    the hinge has a pin in the middle and about 250mm long..
    any ideas folks where i can find form tool for this sort of hinge?
    Apr 2008
    6
    Hinge tool
    I can build a tool to produce the hinge for you. What type of press do you have to run the tool in? Do you have any drawings or specs for the hinge?
    Randy Jones
    Florida Mtn. Machining LLC
    4130 Cordoba Rd. SE
    Deming, NM 88030
    Sep 2007
    138
    Hi..type of press :
    80 ton press brake
    model Finn-power
    something like this:
    http://www.satobrandt.no/Content/Fil.../MTB_E_map.jpg
    so when you say you can biuld tool, is that hardware or on cad software?
    becasue I am in New zealand and shipping wise is maybe is a bit over much for tool like that..
    the hinge is:
    is simialr to piano henge at least 250mil long and there will be pin the middle..
    my boss says he might need to do it on 2 stages?
    Mar 2007
    7
    Wilson Tool makes a hinge tool set for use in a hydraulice or electric turret punch
    www.wilsontool.com
  1. Forming 1/4 CRS
    By Chris@PREBOLA in forum Bending, Forging, Extrusion...
    Last Post: 02-02-2009, 04:24 PM
  2. VAcuum Forming
    By rhundl in forum Employment Opportunity
    Last Post: 06-28-2008, 04:28 AM
  3. Replies: 5
    Last Post: 04-20-2008, 01:16 PM
  4. Need help forming a dish
    By siowenson in forum Bending, Forging, Extrusion...
    Last Post: 08-24-2007, 09:26 AM
