Does anyone know where I can get the electric schematics for a hitachi seiki HT 20S III?
thanks
goyo
thanks
goyo
I may have this at my office (pdf version) ...I'll check in the morning.
thanks, Standing by......
Only have the machining center schematics on the server. I have several customers with that machine, not sure if they have the same control as you do. Do you need the entire copy or are you in need of just the section pertaining to a particular problem (I might be able to get them to scan that section of the document if necessary)? If you need the whole copy, then I suggest you contact your local Mori dealer and see what they would charge you (if at all) for a copy.
thanks for the reply,
We transfered the machine to a dif location and after new install the spindle won't turn,
So anything related to the spindle will help.
thank you
OK, I will ask around. What is the control? What is the spindle drive unit? Is there an alarm on the screen or the spindle drive unit?
the control is a seicos LY it has a yasnac controller and no alar5m display's om the screen, only a red light on the board where thers a question mark button,can i send you pictures of the control?.
thanks
ernie
Yes, you can send me a pic to: kevin@cnctechnical.com
pic's are sent,,,,also the spindle is very hard to turn, I removed the v belts to see if motor was lock and no it spins by hand, so as soon as i push the spindle button I get the red light on controler,, see picture....
thanks
hello
still need hel with elec schems,, any takers?
thanks
Ernie,
what is it you need? I have the electrical diagram, but what control do you have? And what alarms?
John
