588,571 active members*
6,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hobby milling machine - with a small budget
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Jan 2004
    13
  2. #22
    Jan 2004
    490
    I had an idea a while ago about a mill, or a lathe, that uses a spindle and hub from a car. That way you get tapered roller bearings, and already machined shaft and bearing races. Wouldn't be able to put a spindle bor in the thing though. Had another idea about using the bottom of an engine block, or two connecting rods as the journals for a lathe or mill, and simply having a machine shop turn down a piece of heavy pipe for the spindle itself. That would be the only thing that would have to be done on a lathe.
    Stop talking about it and do it already!!!!!
  3. #23
    Feb 2007
    Hi from England,
    I have been looking at Chinese mills and all the components needed to set up a cnc mill, this comes to £ 800 plus £800 which is a bit too much. Where I work has large lumps of metal of bright drawn, so I have been drawing out some ideas on a minimum machining mill all from sections very similar to Dave Gingerys but without all the castings.
    David. in Devon.England.
Page 2 of 2 12
  1. Maho MH600E Milling machine questions???
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2009, 07:51 PM
  2. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  3. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  4. which milling machine to start out with?
    By cowanrg in forum Benchtop Machines
    Last Post: 01-18-2005, 11:34 PM
  5. Allocating room for a new hobby machine shop
    By CactusChip in forum Community Club House
    Last Post: 03-29-2004, 07:58 AM
