587,997 active members*
1,807 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Holding square stock in a pusher collet
    Jan 2013
    I have a Ganesh cyclone lathe with a patriot bar feeder. I am turning 3/4 square stock. Problem I'm having is keeping the stock held in the pusher collet. I'm currently holding on the "points" of the square and putting a pin thru the pusher collet to hold it in. Doing this means I have to manually load each bar. I've tried turning the end round to 5/8 , using a 5/8 pusher collet. The square bar eventually works it way out of the pusher collet.
    Anybody have any ideas to try ?
    Jan 2010
    134
    Re: Holding square stock in a pusher collet
    If you've prepped the bars by turning the end, and it's still coming out, then you have a problem with the barfeed not pushing during machining/collet open etc. Are you certain your barfeed is operating correctly?
  1. c5 collet holding multiple parts in one holder
    By redridertwo in forum MetalWork Discussion
    Last Post: 03-06-2014, 03:50 AM
  2. Square stock only?
    By snoman70 in forum Cut2D / Cut3D
    Last Post: 11-04-2013, 07:00 PM
  3. square stock
    By 707Chipper in forum Benchtop Machines
    Last Post: 02-03-2012, 04:28 PM
  4. Hex Stock = not holding diameter tol's?
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 05-31-2010, 07:39 PM
  5. Holding Flat Stock on a mill
    By John Lorbiecki in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2007, 02:00 PM
